Works when it gets warmer outside.
Old Apr 12, 2008 | 05:42 PM
Motorsportsartist's Avatar
Motorsportsartist
I have a 2000 Ranger XLT 4X4 with a manual 5 sp.I have put 239K on the truck so far. The truck is still in good shape and I have had to do very little to the truck. I replaced the Alternator and last year I did the valves and replaced the brakes and one clutch and thats it. I do have a problem with two thing though the door ajar light comes on all the time but not when it cold outside and the oil pressure gage reads zero if the outside temp is under 50 degrees and works fine above 50. The gage will read zero till the engine get some heat in it and then works fine. any ideas?
