Installing Split Bench Seat
Old Apr 13, 2008 | 01:36 AM
Equestriana's Avatar
Equestriana
but the seats are connected, its one big seat at the bottom, only the top is split. So its not possible for the two sides to slide independantly.
I think its the piece needed to allow the drivers side seat to fold. Thats what i'm hoping it is, otherwise thats broken. hah
Old Apr 13, 2008 | 01:38 AM
Equestriana
I assume the tracks are bent to follow the shape of the truck better. My current tracks dont really follow the shape, these ones look like they do. I would have to drill new holes though
Old Apr 13, 2008 | 01:41 AM
Shamus's Avatar
Shamus
The floor pan is definitely an odd shape. If your current seat doesn't fit properly, it is most likely a swapped seat. If the new seat tracks fit better use them. Drilling is no big deal since you can use steel tape from the bottom to seal any bad holes.
Give it a go and see what looks best. Most seat swaps wind up with a modification of two. I have swapped twice and continue to use the original bench.
Old Apr 13, 2008 | 04:36 AM
m78's Avatar
m78
Originally Posted by Equestriana
Nope, doesn't have a center track.
Now it does have this long skinny metal piece. The guy said it should clip right on (I believe its needed to allow the driver side to fold down) but I can't figure it out... Anyone know what this piece is?
Could the guy you bought it from not know what he's talking about ?
The only differance between the seats (less track) should be the split back.
The supercab backs have 10" cables inside to release the latch and fold forward individually.
The regularcab should have a long piece to tie the two latches together.
Old Apr 13, 2008 | 09:39 AM
76f350spercamprspeal's Avatar
Would the little back bench seat even fit in the front of a standard cab???
Old Apr 13, 2008 | 10:43 AM
Equestriana
The seats not little, same size as my current seat. So theres no way its the back seat.
I'm pretty sure the guy knows what hes talking about, I e-mailed him to see what he says. I'll report back when I figure it out
Old Apr 13, 2008 | 11:07 AM
oh ok.......
