swapping rear-ends
Old Apr 11, 2008 | 11:13 PM
hammerhead90's Avatar
hammerhead90
swapping rear-ends
Alright, so I have a 2wd 1988 150 with the 3.55 axle. That's great and all on the road, but if I need to go up a moist grassy hill, I just spin and go back down again.(not to give a sob story or anything, but it almost got stuck because I had to move over and stop for a fire truck)
So I've decided to switch it with a used locking rear with the same gears, and I was wondering how difficult it would be, or if there are any modifications needed for the swap.
Appreciate the input.
Old Apr 11, 2008 | 11:19 PM
khadma's Avatar
khadma
Carpenter Local 745
Just get a traction device and have a shop install it.
You will be on the road in no time.
Link for you for some input.
1822 - Richmond Gear - Ford 8.8" 10 Bolt 31 Spline 7/8" Shaft Open Diff Lock-Right | Tellico 4x4
This may not be the proper unit for your truck, but it will give you an idea of your options.
Old Apr 12, 2008 | 05:39 PM
Dre82s's Avatar
Dre82s
if you have the whole locking rear end housing and everything just jack up the truck and loosen a few bolts and out with the old in with the new. now if you are trying to get in there. take it to a shop
Old Apr 16, 2008 | 08:35 PM
lostin90s's Avatar
lostin90s
The swap whole rear is easy but LS or a rear with after market locker r hard to find. Luck is u have 3:55 which is common.
