hi all,my first time on this site and i,m hearing a lot of good advice.read some answers on frame painting and i too am redoing a 1956 ford f100 from the ground up.my first time taking on a project this big,but wanted to do for a long time.i need to pull the engine & trans and the frame will be all mine.the cab needs the cowls and two front floor panels replaced but other than that,all the other body parts are in good shape.i,m going to try to do a lot of the work myself,so i,ll need a lot of suggestions down the road.. thanks for listening,,gary,out of waterford mich.
You are at the best site for any help you need on that project. A lot of folks like the 56 and there's a bunch around in various stages of restoration. You also might be able to find some other folks doing similiar work in your state chapter: Michigan Chapter - Ford Truck Enthusiasts Forums
