Need Help Please
Old Apr 11, 2008 | 10:29 AM
Grinny69's Avatar
Grinny69
Cool Need Help Please
Newbie to this site so not sure what to expect, anyways my problem is a noise in the front of the engine when there is a strain on the motor, sounds like a belt or a pully its not a sqeel noise more like a bad bearing any ideas on what it could be???
Old Apr 11, 2008 | 11:55 AM
kboughton's Avatar
kboughton
Sounds like your idler Pulley bearing (probably not the right name) needs replacing. This is the wheel at the top directly under the shroud. Does it squeal on really cold days, at idle or on the highway? I had a similiar problem with my 97, 150 and my buddy has it with his 04.
Old Apr 11, 2008 | 11:57 AM
f-150 on 22's's Avatar
f-150 on 22's
If you have 4x4, it could be your hubs
Old Apr 11, 2008 | 01:50 PM
Grinny69's Avatar
Grinny69
Its not a squel its more like a bad bearing and it doesn't make any noise at idle only when theres strain on the engine.
Old Jan 28, 2009 | 07:54 AM
mwil809's Avatar
mwil809
Grinny69 did you ever get an answer on your problem. Mine is doing the same thing. it sounds like a bad bearing on a pulley in the front of the motor when its under a load. Any suggestions would be very helpful. thanks
Old Jan 28, 2009 | 05:00 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Belt tensioner? Sounds like the belt is being dragged? It's hard to explain, but your belt tensioner might not be tensioning correctly...I've seen it twice before. Do you floor your truck a lot through the gears?
