Sponsored by: Auxito
Spark Plugs
Old Apr 10, 2008 | 10:09 PM
DJPRacer58's Avatar
DJPRacer58
Spark Plugs
About how often should i change the plugs on my truck. and where are they in the engine? i have looked every ware and cant find them. 99 f150 5.4
Old Apr 10, 2008 | 10:35 PM
xtrford's Avatar
xtrford
They a hidden under the COPS or "coil over plug" style ignition and are deep into the heads. You have to remove the COPS with a 7 or 8mm socket and use a variety of extensions to remove the plugs. Do a search on "plug change" and you should plenty of information to attempt the job yourself. First time took me roughly 2 hours so don't rush yourself....now I can do it in under an hour.
I personally change my plugs every 3 years, they are platinum and Ford recommends every 100k per change (that could have changed now) but I find that is going too long. Make sure you use Motorcraft or Auolite plugs ONLY in these modulars if everything is stock...many have complained about rough running engines using the Bosch and other aftermarket plugs.
Old Apr 11, 2008 | 12:57 PM
DJPRacer58's Avatar
DJPRacer58
thanks. i also heard that its easy to strip the threads when taking out the old plugs in these motors. is that true?
Old Apr 11, 2008 | 01:20 PM
xtrford's Avatar
xtrford
I have never heard anyone have troubles taking them out, only when installing new ones and not to under/over torque them.
mrsvegan
17
Oct 19, 2013 07:26 PM
jspringator
Modular V10 (6.8l)
Oct 19, 2013 08:50 AM
stevelacey75
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 12, 2004 08:29 PM
shakespearesdad
Oct 27, 2002 08:54 PM
millbobs
Mar 30, 2001 06:26 PM
