Big Problem?
Old Apr 10, 2008 | 06:55 PM
76f350spercamprspeal's Avatar
Smile Big Problem?
My Carb (Holley) Leaks gas!
Could this cause my truck to catch on fire?
Your Friend
76SCS.
Old Apr 10, 2008 | 06:59 PM
Virto's Avatar
Virto
With any luck.
Seriously, yes. When you say leak, is it a trickle, is it spraying? Is it a fuel line or is the carb pouring gas out of the top?
Old Apr 10, 2008 | 07:11 PM
jwtimme's Avatar
jwtimme
a little more info might help us help you.
Old Apr 10, 2008 | 07:27 PM
TailGater_73F100's Avatar
TailGater_73F100
Don't be that guy.
Old Apr 10, 2008 | 08:12 PM
A couple drops.
Old Apr 10, 2008 | 08:28 PM
crescentwrencher's Avatar
crescentwrencher
yes, your truck has serious potential of bursting into flames,
being that its a slow trickle, and im guessing its coming out of the base plate, it might be a misadjusted float.
its a pretty easy fix and a common problem.
Old Apr 10, 2008 | 09:19 PM
Mil1ion's Avatar
Mil1ion
I think we already suggested it was the accelerator pump.
Old Apr 10, 2008 | 09:30 PM
73f100shortbed's Avatar
73f100shortbed
Yep it is possible. Might also make it worse with your wandering problem that you posted under "Stearing question". If you swerve off the highway into the ditch it could burst into flames. That wouldn't be good.
Old Apr 10, 2008 | 09:37 PM
Mil1ion's Avatar
Mil1ion
Maybe it's time to sell that truck that seems to have so many problems and buy another one ? Tim
Old Apr 10, 2008 | 09:42 PM
SuperSnake's Avatar
SuperSnake
Heck get a carb,gear box get it going..
Old Apr 10, 2008 | 10:01 PM
fmc400's Avatar
fmc400
MSEE
Basically any source of fuel has the potential to catch on fire. Is it safe? No. Do countless trucks have the same problem? Yes. Should you do something about it? Yes. Holley carbs are prone to leaking because the fuel bowl attaches sideways with a gasket; so there is a mating surface that has fuel pushing against it at all times, due to gravity. That is one source. The other source is the accelerator pump. To fix those, replace them. The other possibility would be throttle shaft bores or a crack in the throttle body casting.
Old Apr 11, 2008 | 01:08 AM
dwbachor's Avatar
dwbachor
The newer holley carb kits have "reusable gaskets", I don't recomend reusing them but they resist drying out and leaking much better than the old ones. Buy a holley trick kit and redo all the gaskets. If this doen't fix the problem and you have checked the throttle body shafts you might want to consider a new carb. Make sure you torque all the gaskets carefully in a cross patern to ensure that everything pulls flat (make sure gasket faces are kleen and there are no burrs.
Old Apr 12, 2008 | 05:41 PM
Smile
Dont Scare me like that!
Old Apr 12, 2008 | 08:30 PM
73f100shortbed
Well hopefully you can get this stuff fixed soon and you won't have to worry
Old Apr 12, 2008 | 09:27 PM
boggin79ford's Avatar
boggin79ford
i think youve got yourself a lemon.
