Rough running 302.....
Old May 17, 2002 | 11:26 PM
Wilber15's Avatar
Wilber15
If it ain't broke.....change stuff till it is!
Ok..i own an 86' f-150 4x4 with the 302 efi. when i start it up, it runs fine, but after it warms up it starts to run rough with a varied rpm reading. the rpm's will vary from like 400 to 700. they go up and down randomly. is this a clogged cat.? or a vacuum leak of some sort? what can i look for and where is it on the engine...thanx.
I just changed the plugs. Also, if i step on it after driving a while(while in park and rev. to about 300 rpm's) black carbon smoke comes out the pipes. could this be a fuel filter too? any help would be appreciated....
Old May 18, 2002 | 12:04 AM
Wilber15's Avatar
Wilber15
If i was to purchase and replace the fuel filter and 02 sensor, would this help in the rough idle too?
Does the 86' f-150 4x4 have 1 or 2 filters?
Old May 18, 2002 | 09:54 AM
cajunbronco's Avatar
cajunbronco
Sounds like it may be running rich(black smoke).That can cause a hunting or surging idle.
Billy
Old May 18, 2002 | 11:48 AM
John15016's Avatar
John15016
Bring the engine up to temp first. Try the IAB valve on the intake of the Throttle body, it is sticking. Buy a replacement gasket (felt) and remove the IAB body from the housing, spray carb cleaner in it and let it sit. Also spray into the throttle body to remove any visible dirt. Let it dry of any excess in there and reinstall. The engine will not start up right away, but it will. Sure worked for me.
John (JC)
1977 F150 302
1987 Nustang GT (244K and still running new)
Old May 18, 2002 | 08:53 PM
Wilber15's Avatar
Wilber15
How do u change the rich mixture? I took the TB off today and sprayed it out along with the IAB, and it runs a bit better. btu it still sounds like the engine is shuddering when i go to slow down at stop signs. it feels fine accelorating, but goin into stop signs is when it sounds and feels terrible. is this a plugged cat? if so, whats the easiest way to go about knocking the crap out of the inside? i don't want to replace it , because we don't have strict emission laws, so if i can just get the stuff out and leave the shell, that would be great. also...could an exhaust manifold leak cause this surging?
Old May 18, 2002 | 09:05 PM
Wilber15's Avatar
Wilber15
fatherof4
May 30, 2014 10:17 AM
jlarocca95
Aug 5, 2010 05:09 PM
Kep4
Jul 1, 2010 03:32 PM
strokin'_tatsch
Jun 17, 2010 12:11 AM
RC Dan
Jun 16, 2007 10:21 AM
