Oil Pressure Guage Problem
Old Apr 10, 2008 | 03:49 PM
murphy's Avatar
murphy
Hey, my oil pressure gauge on my 4x4 Ranger began oscillating wildly at idle, then went dead. Plenty of oil, engine runs fine. Bad pressure sensor I guess ? Where would I find the sensor on a 1999 3.0 V6 ? No luck looking by the oil filter.
Old Apr 10, 2008 | 04:10 PM
murphy's Avatar
murphy
Disregard, thanks anyway.............
Old Apr 10, 2008 | 04:11 PM
Bear River's Avatar
Bear River
Former ******
If it is like the 3.0L used on the Aerostar, it should be on the back of the engine, on the passenger side. You model does not have a distributor, but it is close to where the distributor would be.
Old Apr 10, 2008 | 05:49 PM
murphy's Avatar
murphy
thanks, replaced the sensor and the gauge indicates low pressure. Engine runs strong with no noises, excess heat etc.
Old Apr 10, 2008 | 06:55 PM
murphy's Avatar
murphy
Well, I figured it out. There is a small plastic pin that the needle rests on, on the face of the gauge. The needle had jumped around enough to go past the pin and was prevented from returning to mid-range by the pin. Broke the clear-plastic cluster cover in the process though..................
Old Apr 11, 2008 | 04:04 AM
munalab's Avatar
munalab
hi there,
I would like to know what the po 174 stands for in my F150 2002 XL? I got this code when the service engine light came on. Where is this sensor located? Can I replace it? since I know enough about cars and I am handy around them.
Thanks
Old Apr 11, 2008 | 04:11 AM
khadma's Avatar
khadma
Carpenter Local 745
OBDII codes
TroubleCodes.net- engine & OBD2 Trouble Codes and Technical info & Tool Store.
You might have an air leak.
Old Apr 11, 2008 | 04:16 AM
khadma's Avatar
khadma
Carpenter Local 745
Murphy,
The stock OP gauges are basically just idiots light with a needle, the dash reading will either be on or off, just like a light bulb. There is no way to tell the actual OP with the stock gauge. (it moves to "normal" position at around 6 psi) anything lower than that, the gauge is "off".
Old Apr 12, 2008 | 08:45 AM
Bikeitswift's Avatar
Bikeitswift
Interestingly enough, just yesterday, my 2002 3.0 (41,000 miles) started doing the same "Oscillating " thing. Came to a stop light after cruising at 65 mph, and the gauge started dropping, then 'snapping' back. Ran solid in the middle once I took off, same thing happened at next light. Stopped, checked oil (was fine), symptom never returned. Is my sensor going out, or is a random event like this acceptable? Drove another 150 mostly highway , no problems noted.
Old Apr 13, 2008 | 11:54 AM
murphy's Avatar
murphy
The OP gauge is still bouncing even after a new sensor installation, must be the gauge.
Old Apr 13, 2008 | 11:59 AM
khadma's Avatar
khadma
Carpenter Local 745
GET A REAL OP GAUGE. Mount it on your A pillar be happy and accurately informed from now on!
