e4od trans controler
Old Apr 10, 2008 | 03:27 PM
mousetrap65's Avatar
mousetrap65
hi. I have a 90 f250 351w e4od 4x4 moter went bang so I pulled it and found rebuilt carbed 351w to put back in. have heard of a trans controler
does anyone know where to get one. or do I need to find a c6 and transfer
case to get the old girl up and running.
Old Apr 10, 2008 | 03:52 PM
85e150's Avatar
85e150
Not free, but cheaper and easier than the c6 convert.
Have you considered keeping your efi, ecu etc and transfering to the new motor?
Electronic Performance Products -- Baumann Electronic Controls, LLC
Old Apr 10, 2008 | 06:12 PM
mousetrap65
didnt know I could short block on efi moter is toast but heads up are good
short block on carb moter is all I have need heads up
so you are saying I can use carb block and put heads up from efi and it will work?!!!
Old Apr 10, 2008 | 11:54 PM
85e150's Avatar
85e150
Best place to post this is in the Small block windsor forums. Explain your two engines. I would think it's simple bolt on, but with Ford, you never know. The cam might be an issue too, but I know from reading those threads there are several very savy guys on the 351 and you'll have an answer in a day.
Even if you have a challenge or two, I think it would be worth it. Best thing, is the first step (see above) is free.
Good luck.
