351 W knocks
Old May 19, 2002 | 11:34 PM
CowboyMjoh's Avatar
CowboyMjoh
351 W knocks
I recently gutted my 83 f-250s stock 351 W; igniton, emmissions, computer, and replaced it with an edelbrock package, carb,cam, and intake. I got a points distributor from a 70 351 W, there was a loud knocking from the front of the engine after I started it. The stock duraspark 3 distributor shaft is an inch longer than any other 351 distributor that I can find. Could the different distributor shaft not be catching the oil pump shaft, causing the knocking? I also put a timing set in, if that has anything to do with it. I would greatly appreciate any help or insights, I am stumped with this one.
Old May 19, 2002 | 11:48 PM
sauerf100s's Avatar
sauerf100s
351 W knocks
If the original distributor is an inch longer, you must be trying to use 302/289 length distributors instead. If the replacement distrbutor doesn't go down into the block the same amount as the one you took out, it will not turn the oil pump. You ran your engine with no oil pressure. I hope you didn't toast your bearings.
Old May 20, 2002 | 12:08 AM
CowboyMjoh's Avatar
CowboyMjoh
351 W knocks
I already checked about five parts houses and had them show me many different 351 distributors for a 351 W. The duraspark 3 distributor shaft is one inch longer than ANY other 351 winsor distributor shaft out there, unless I am missing something. Yes, I made sure that the one I swapped was from a 351 windsor. It's weird.
Old May 20, 2002 | 12:09 AM
CowboyMjoh's Avatar
CowboyMjoh
351 W knocks
Oh, also, there was good oil pressure while cranking.
Old May 20, 2002 | 12:22 AM
Franklin2's Avatar
Franklin2
351 W knocks
That doesn't make much sense does it? Since you have so many friends now at the parts houses, see if the oil pump drive shaft has a different part number for duraspark III. It would have to be shorter if the dist is longer. Or maybe it just slides up in the dist farther. I would also check the fuel pump. I have never had a Ford pump make a noise, but I would guess it is possible if it was worn out, or if something didn't get put together right on front of the cam.
Old May 20, 2002 | 01:13 AM
CowboyMjoh's Avatar
CowboyMjoh
351 W knocks
I put the eccentric on right, probably not that hard to mess up, but it could happen, fuel pumps new. I'll check them out like you suggested. Thanks.
Old May 20, 2002 | 07:32 AM
slikness's Avatar
slikness
351 W knocks
[updated:LAST EDITED ON 20-May-02 AT 08:34 AM (EST)]It might be the distributor is just catching the top of the oil pump and cranking the pump enough to give you good pressure and low rpms...my son did this on his truck (didn't seat the distributor) and as soon as it reached 2000 rpms, the pressure would drop...reset the distributor and never had a problem...
Stop monkeying with the Motorcraft distributors and get an MSD...it will save you ton's of grief...
And why would you go back to points?????
Old May 20, 2002 | 11:58 AM
fairlane63's Avatar
fairlane63
351 W knocks
Bluetorpedo
28
Mar 11, 2017 08:50 PM
51chris
Apr 17, 2016 03:39 PM
rocfire
Jun 8, 2014 01:26 PM
Bamadawg63
Feb 23, 2014 08:16 PM
whisler
Dec 11, 2011 07:42 AM
