Offroad & 4x4
Tougher leaf springs
Old Apr 9, 2008 | 09:13 PM
mudslingur's Avatar
mudslingur
I was haulin a load of feed in my 150 today and realized those leaf springs can't really handle the weight that good.Im assuming since they have built in lift they can support weight like the stockers can.
I am just wondering if anybody knows if a set of leaf springs out of a newer super duty can be swapped in to a 77 150 4x4.
Thanks
Old Apr 9, 2008 | 09:17 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Nope wont work. None of the dimensions are the same. As for lift springs they have a lower GVW than factory springs.
Old Apr 9, 2008 | 09:20 PM
MBBFord's Avatar
MBBFord
The superduty leafs will not swap in place.
Some 73-96 3/4 or 1 ton rear leafs should fit and be able to hold more weight, but how much weight are you putting in the bed?
There's always the option of putting a add a leaf...
Old Apr 9, 2008 | 09:22 PM
Ryan50hrl's Avatar
Ryan50hrl
you could put in some airbags to compliment the springs when you're hauling stuff
Old Apr 9, 2008 | 09:29 PM
mudslingur's Avatar
mudslingur
It was about 700 pounds.I guess since i was used to the weight capacity of the old springs,these just seem weak.
Will add a leafs work on leafs springs that have built in lift?
Bags sound like a good option too,but wont they be prone to tearing open when Im driving through the brush
Old Apr 9, 2008 | 09:46 PM
Ryan50hrl's Avatar
Ryan50hrl
Bag are pretty darn tuff....
Old Apr 9, 2008 | 09:51 PM
mudslingur's Avatar
mudslingur
i'll look into a set of bags.I can weld, so if i have to I can always make the brackets
Thanks for the replys
Old Apr 9, 2008 | 10:00 PM
dragogt's Avatar
dragogt
or as a alternative to bags check out these...Timbren overload rubber helper springs ---Free Shipping on Timbren kits
Old Apr 10, 2008 | 06:50 AM
fishmanndotcom's Avatar
fishmanndotcom
way tougher than anyone gives them credit for. aside from trucks sitting for years and due to dry rot i dont think i have ever seen a bag just cut from debris. they are thick like a tire. virtually all over the road tractors run them
-cutts-
CaptFX4
2004 - 2008 F150
Jan 18, 2013 05:57 PM
mikes6tfourd
1997 - 2003 F150
Oct 3, 2011 10:08 PM
rockcrawler_101
May 27, 2011 12:08 AM
clhart426
Sep 17, 2010 06:30 PM
Windsor84
May 13, 2005 07:00 PM
