Grounding strap...
Old Apr 9, 2008 | 08:48 PM
ottawaguy's Avatar
ottawaguy
Grounding strap...
I found a ground strap today in the engine compartment that is attached to the firewall directly in front of the passenger seat. The other end is not connected. Is this an engine ground strap? I could post a pic, but I'm sure most will know the strap I speak of.
It has a flat loop at the loose end I believe...so I'm guessing a bolt came loose somewhere.
Can someone tell me where it connects to?
Many thanks
Old Apr 10, 2008 | 03:35 AM
TexasGuy001's Avatar
TexasGuy001
If it is just above the heater box, it goes to the hood. I have the same thing and it broke in half. It is still connected on each end. It has been this way for a while. I tried to join it back together a few times but it never stayed. I don't know what it is for. Look on the hood and see if there is a rivet near that location. I was thinking about drilling out the rivet and replacing the ground strap.
Old Apr 10, 2008 | 04:54 AM
EPNCSU2006's Avatar
EPNCSU2006
If the hood strap is still there, the other grounding wire at that same bolt on the firewall goes to the engine -- most likely a bolt on the intake manifold.
Old Apr 10, 2008 | 07:49 AM
TexasGuy001
I just looked at mine and the ground from the engine (intake bolt) to the firewall is separate and has its own bolt. If that is what is broken on yours, I would fix that.
Old Apr 10, 2008 | 09:13 AM
ottawaguy's Avatar
ottawaguy
Here is a pic of the strap in question...the attach point on the firewall is circled.
Now I don't see a strap to the hood...but I don't see a grounding strap to the engine either.
Old Apr 10, 2008 | 06:19 PM
TexasGuy001
The strap on the hood is by the hinge not to be confused with the spring. You can barely see it in you picture. It looks like your hood strap is attached. The strap in your picture that is not connected to anything goes on the bolt/stud on the bracket between the exhaust manifold and the upper intake.
Old Apr 10, 2008 | 07:47 PM
EPNCSU2006's Avatar
EPNCSU2006
I agree...based on the size of the eyelet, it should connect to a bolt on the intake manifold.
Old Apr 10, 2008 | 08:12 PM
icrman's Avatar
icrman
I'm too lazy to run out an look, but I think its conneted to the brackets that hold the AIR system hoses etc. I remember disconnecting and hooking one up there.
kindorotten
24
Aug 21, 2016 10:18 AM
Millam
Aug 4, 2015 11:05 PM
66ca
13
Jun 20, 2010 06:27 PM
EHC112
Nov 2, 2009 05:28 AM
H2OnO2
1978 - 1996 Big Bronco
Mar 19, 2009 04:55 PM
