Sheared Pin
I sheared the pin in the rear end of my 94 F150. It looks like the bolt that holds the pin in place backed the whole way out because i found it intact at the bottom of the rear end in the oil, but the pin was in 2 pieces. The 2 gears that were on the pin look fine but they were on the bottom also
Can i just put another pin in and be done or do I need to remove the posi unit to do that
I am able to get another rear axle and just do a whole swap but i would need to change over all my brakes and lines and all that and it seems like a lotta work.
I need to get this done as cheap as possible because i have very little funds
Thanks for reading
Be sure to flush the housing out if you reuse it. And be sure that the holes in the carrier are not enlarged or elongated in one direction. They should be a close fit on the new pin. a tiny bit of lock-tite on the pin will keep it in better too. let it set up before adding the lube.
To clarify what exactly happened i was backing up my driveway about 10 miles an hour when it came to a sudden stop, i wasn't sure what happened i thought i broke something in the tranny so i figured why not try 4x4 i put it in 4 low slowly let out the clutch then... Bang truck moved freely. and that is where i am at now.
I can move the truck if i engage 4x4 i alreaqdy removed the broked pin and the gears that were riding on it so i am not worried about any more damage. The pin hole looks good and there are no teeth missing or anything i guess i will find out if everything is alright when i put the new pin in
