2007 F-350 crew cab stereo build
#46
mooch nice setup any finished pics just a thought if your truck had the metal plate under the seat use it mount ur amps. that what i did i removed the hinges and got rid of the extra pieces then carpeted the main part that bolts to the seats, just a thought but very nice.
stev3-0 I had an 01 that didnt have the power rear power window and i had a systme in it. when i traded for my 06 i kept the system only to find out that the box wouldnt fit. I looked everywhere and noone makes a 12 in sub box to go behind the seat and accomodate the window unit. I have a procomp box and mtx 5500 series sub, so i got creative and did some measuring and notched the box to fit around the window unit. If u want 10in or 8 in there are boxes available but if you want a 12 you will need to get creative like i did.
#47
#48
#49
#50
Wanted to put together an update on my install.
Some may remember that I was fretting over the cleanliness of the tweeter pods I chose to install to mount my Alpine Type X tweeters. I finally figured out how to get rid of an unsightly gap between the pod and the door panel.
Here is a shot of the "gap" on the drivers' side:
And a shot of the same on the other side:
Separated one of the horizontal supports on the back of the tweeter pod and got creative with a couple of strips of 1/4" MDF:
Now they sit such that they cover up the gap on the door panel:
The pictures don't do them justice, but I think they look quite finished and the lines blend well with the door panel.
#51
Fabricated some mounts for the Alpine 1" tweets that would use the existing Ford mounting holes on the underside of the tweeter pod. This had the advantage of positioning the tweets a bit more on-axis than the quick-fix setup I had been using. Used 1/8" ABS sheets which scores and snaps very easily to make basic shapes.
#52
Almost had a JL 500/5 purchased but found such a great deal on the original JL slash amps through an authorized retailer that I could not turn down a little extra juice. The 500/5 would have given me a few extra watts for the front soundstage, but would have cut the delivery to the sub in half. I was concerned that 250W to the sub would not be enough.
#53
#55
heres the links for a couple of pics i took of my amps hope it works for ya http://i172.photobucket.com/albums/w...keremt/007.jpg http://i172.photobucket.com/albums/w...keremt/012.jpg
the wires are a little messy just havent finished hiding them. the cloth is a thick black fabric i picked up at wal mart and i glued to the plate the amps are held in place by heavy duty velcro maybe you can u se this set up or maybe it can help you out.
#56
#57
Unfortunately they weren't cheap, but not that much as I remember. I thought closer to $80 for the pair. Buying them "loaded" with the tweeter was the only option available. Try one of the online vendors Ford parts vendors for a better price if that's one you got from a local dealer. Good luck!
#59
It's been a while.
Over the past few months, the F-350 has become a daily driver for me and I've had a lot more time spent listening and adjusting. After four years, I'm still not entirely happy with the system, but I continue to make changes and tweaks.
So over the past three years since I updated this build, a number of things have changed.
First, at some point I blew the woofers on the Alpine SPX-17REF set. I'm not sure if this was a result of the way I was running them, a function of the aluminum woofer cones, or if they were contacting the door panel when installed:
I've had an open return authorization with Alpine to send them back and have them looked at, but I never shipped them out. Knowing they are well out of warranty, I didn't think there's anything they would do about it, but I might just ship them anyway since they're no good as they currently stand.
I ended up at one of my local brick and mortar stores looking for replacements and ended up coming across a set of these:
For better or worse, knowing there was a lot of forum popularity around these speakers when they were first introduced, I figured I'd give them a shot. They were BNIB, heavily discounted, and probably the last pair available in New Jersey.
#60
I also built new speaker baffles (poly cutting boards do work well and are easy to cut with a jigsaw). In addition, I sealed and deadened my front doors heavily. Sealing required I cut three pieces of sheet aluminum in the approximate size of the hole, deaden them, and then screw them in to the door (using vinyl weatherstrip tape to seal beneath):
Couldn't do much more than this because the door panel hooks in through the remaining open holes.
