now what?! same problem!
Old Apr 9, 2008 | 07:36 PM
jbirdsvt's Avatar
jbirdsvt
lxman, i tried what you said and took the carb off, took it apart, and cleaned it. i didn't find any debris down inside anywhere. i took apart the fuel bowl and the accelerator pump and couldn't find anything. i shot out all the jets and passages with carb cleaner anyway. i put it all back together and started it up and it definitely seems to run smoother, but i still have no off-idle throttle response. it's still doing the same thing. i've found that if i hit the throttle hard from idle, it makes a sucking sound and just bogs, and if i hold it down after hitting it hard like that, it will actually cut off. if i ease into the throttle it's fine. the accelerator pump seems to be functioning properly, but i don't really know what it looked like before. i took it apart and the diaphram is intact and everything looks fine. what else could this be?!
Old Apr 11, 2008 | 09:04 PM
LxMan1's Avatar
LxMan1
Are you talking any opening of the throttle or alot of throttle?
Where is the timing set? is the advance working?
