Grinding from front driver-side wheel
Old Apr 9, 2008 | 04:24 PM
JaySVX's Avatar
JaySVX
1998 Ford Expedition EB 5.4litre 4x4 - 116,xxx miles
When I go around a bend, tight bend at that, at low speeds, under acceleration(and sometimes not), I get this grinding sound, for about 25% of the wheel revolution. The situation is consistent with a bad CV joint on a fwd vehicle, however the sound is not.
I was going to jack it up this weekend and replace the axle, as well as the little thing that makes my AWD not work. Some little magnetic actuator from what I've been able to determine. I also plan to get all 4 wheels off the ground so i can put the truck in gear and see if the front tires are not moving, just to make sure I'm not in 4wd.
Also, last time I had it in 4LO, I couldn't get it out. I turned the switch back to 4HI, backed up 10ft, all the tricks, but it wouldn't go out. Finally I moved it to park, then reverse, and it popped out, but with a horrible grinding sound. Any ideas? 4HI has not given me any problems, so I've been using that.
Old Apr 9, 2008 | 04:36 PM
NWBronco's Avatar
NWBronco
You'll be pulling the rim off to do all this, check the brakes while you are down there. They'll grind a bit, too upon wearing down.
As far the 4Lo shift. YOu should have been in neutral with your foot on the brake when playing with it. It changed in gear, kind of like missing the clutch and hitting the stick anyways. 4Lo will just about always grind if you try to switch it and then shift the gears.
JaredM91
Dec 3, 2013 05:08 PM
mzender
2004 - 2008 F150
Jan 24, 2013 04:37 PM
speedfreak87
1983 - 2012 Ranger & B-Series
15
Nov 6, 2011 06:54 AM
sunogbahay
19
Mar 18, 2011 01:49 PM
drguitarum2005
25
Oct 27, 2009 01:54 AM
