Rear Leaf Question
Old Apr 9, 2008 | 01:54 PM
black04lariat's Avatar
black04lariat
Rear Leaf Question
Can I remove the "rebound" clips as seen in the pictures? Will it effect anything? When I added my AAL it was and still it a bit too long and has been resting on the "bolt" that holds the rebound clips on. I am tired of trying to keep it squeak free with lithium grease. Any help is appreiciated. I really dont feel like taking it all back apart to try and cut 1/4 inch off the length of the AAL.
Old Apr 9, 2008 | 03:01 PM
bwep's Avatar
bwep
Looking at my sky jacker add a leaf mine stops about an inch before the clip front and rear. I really think your going to have to adjust the length of your add a leaf (shorter of course) to keep it from rubbing. Sorry I don't know of any short cut. BTW I have never had any squeaking in my rear leafs. BWEP
Old Apr 9, 2008 | 03:19 PM
black04lariat
Ahhh that is exactly what I didnt want to hear. Its an Autospring AAL and I think the squeaking is coming from it rubbing on that clip... It has actually worn down half of the "bolt" head.
I was just hoping I could take that rebound clip off with a grinder.
Old Apr 9, 2008 | 05:59 PM
Ryan50hrl's Avatar
Ryan50hrl
No...they also keep all of the leafs aligned...
Old Apr 9, 2008 | 06:04 PM
crf's Avatar
crf
i agree with bwep,my skyjacker add also sits about an inch away. sure ur leaf was the right part number??
Old Apr 9, 2008 | 06:29 PM
black04lariat
I dont recall seeing a part # stamped on the AAL, but I do know that the instructions that came with them were correct.
Yea I read that elsewhere on the internet after I posted. Thanks.
Thanks guys. Well maybe someone with a Autospring AAL will chime in and let me know if they are the same as theirs. I have had them installed for like 16k miles and dont have any problems to speak of, I am just tired of the squeak...
Old Apr 18, 2008 | 05:36 PM
black04lariat
Well. I called autospring and talked with them. He too said they should be touching. He sent me some more clips (for free, which was really nice), I cut the factory ones off, ground the rivet flush, and put the new ones on and the squeak is gone.
Its almost like a new truck...I was having the equivalent to a squeaking door everytime I would start or stop, but not anymore.
Old Apr 18, 2008 | 08:29 PM
moonlighter's Avatar
moonlighter
black04lariat... when you installed the helper leaf, did it raise the rearend any? The reason I asked I have a 2" leveling kit on front, when I haul anything it lowers the rearend below level. thanks
Old Apr 18, 2008 | 09:57 PM
black04lariat
Yes. My Add A Leaf raised the rear roughly 1.5 inches. I added it because I tow as well. But...depending on the amt. of weight you are towing, it can still squat...
Old Apr 18, 2008 | 10:00 PM
black04lariat
Originally Posted by black04lariat
Well. I called autospring and talked with them. He too said they should NOT be touching. He sent me some more clips (for free, which was really nice), I cut the factory ones off, ground the rivet flush, and put the new ones on and the squeak is gone.
Forgot the "not"
Old Apr 19, 2008 | 06:16 PM
HYPO's Avatar
HYPO
Since we are on the subject, for you guys with AAL's, did they change the ride appreciably? I have an AS 2.5" leveling kit on my 2008 XLT and will be putting on a Leer cap next week. I have the trailer tow package and like the ride and stance I have now. I occasionally tow a boat and was thinking of adding an AAL to compensate for the cap/ towing. Thanks
HYPO
Old Apr 19, 2008 | 09:29 PM
black04lariat
HYPO
Mine got a little bit stiffer...nothing major though.
Old Apr 20, 2008 | 10:25 AM
HYPO's Avatar
HYPO
Thanks for that response. Anyone else have comments?
HYPO
Old Apr 20, 2008 | 05:55 PM
moonlighter
HYPO
Rides and drives same as stock, I put BD kit on mine 2".
Old Apr 20, 2008 | 08:12 PM
HYPO's Avatar
HYPO
I'm sorry, what is a BD kit?
HYPO
