help over heating trouble
Old Apr 8, 2008 | 08:10 PM
trepid94's Avatar
trepid94
Lightbulb help over heating trouble
hello if you can help i would get rid of my headach i have a 1979 F 250 it has a 300 6cly and 4 spd the truck was over heating and had leaking radiator so i had radiator repaired and installed new thermastate well it still overheated any thoughts ? no leaks any where else
Old Apr 8, 2008 | 08:15 PM
jsutton's Avatar
jsutton
I had that problem and it was air trapped behind the thermostat, I read on another forum a trick of drilling a very small hole in the thermostat to let all of the air through so none gets trapped behind it. When I filled it back up I made sure not to put my top radiator hose on the housing until I saw water coming through the hole I had drilled. I haven't had any problems since. Just a thought and my .02 hope it helps.
Old Apr 8, 2008 | 08:44 PM
trepid94's Avatar
trepid94
hey any help is greatfull thanks
