VIN. Decode please
Old Apr 8, 2008 | 07:26 PM
rusbukt's Avatar
rusbukt
Question VIN. Decode please
F10C0E50572
110 AM F100 29F B 02
5000 146 3800
I no this is a PITA. But the FTE decoder says it is a 4x4. ??
Old Apr 8, 2008 | 08:28 PM
havi's Avatar
havi
I'll have the Roast Duck
Am I to assume it's a 1960? or 1968?
Old Apr 8, 2008 | 09:22 PM
rusbukt's Avatar
rusbukt
1958-60. I purchased it as a 58. No title. Have pics in my gallery. The front turn signals are what throw me off. Some were round. Some were rectangle. Other than that I cant tell the diff.
Old Apr 8, 2008 | 09:38 PM
havi's Avatar
havi
Frank, your truck is a 1960. Here's why: the hood has 2 wide slots, where the Ford symbol (looks like a police badge) sits between. And the grill has 3 rows.
1959 Has the letters F O R D across the front of the hood, and the rows of the grill are without vert. columns.
1958 has 4 rows and round park lamps like that of 1957. And a smooth bumper (the 59/60 have contours shaped for a license plate)
Old Apr 8, 2008 | 10:20 PM
rusbukt's Avatar
rusbukt
Much appreciated havi. Explains allot. Like the fact that the old man I bought it from didn't no Jack.
But then again neither did I.
What I would like to know is how many Custom Cab short beds with the big back glass were manufactured ?
And what the trim package consisted of on the 1960 Custom Cab?
Thanks again
Old Apr 9, 2008 | 01:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by rusbukt
F10C0E50572
5000 146 3800
THE VIN DECODER IS IN-CORRECT! I've run into this before.
If it was an F100 4WD, the first three digits would be either F18 (4,000 GVWR) or F19 (5,600 lbs. GVWR).
F10 = F100 2WD
C = 292 2V Medium Duty
0 = 1960
E = Mahwah NJ Assembly Plant
50572 = 1960
110" Wheelbase
AM: A = Raven Black / M = Corinthian White
F100 2WD / 5,000 lbs. GVWR
Production build date: 29F = June 29, 1960
B = 3 Speed Borg Warner Overdrive.
02 = Ford 9" / 3.89-1 / non Limited Slip / 3300 lbs. Rear Axle Capacity
5,000 lbs. Gross Vehicle Weight Rating
146 HP @ 3800 RPM
I have the FoMoCo production figures, but they're not broken down into specific models like Custom Cabs w/ big back windows.
This is it: Flareside 2WD: 27,383 / Styleside 2WD: 113,875 / etc.
Old Apr 9, 2008 | 01:17 AM
rusbukt's Avatar
rusbukt
Thanks numbers,
The 292 must have got pulled at some point. Because this beast has a 223 in it. ?
Old Apr 9, 2008 | 01:29 AM
NumberDummy
Thanks numbers,
4th digit is the engine code: F10 C 0E50572
C = 292 2V M/D
J = 223 1V
How is the valve cover attached to the head, with two studs, or bolts around the perimeter?
Two studs = 1952/59 = 215 & 223 I-6 / 8 bolts = 1960/64 = 223 or mebbe a 262 I-6.
Old Apr 9, 2008 | 03:24 PM
camperspecial65's Avatar
camperspecial65
I have an extra big back window and trim if you are interested...email me pvt for more info...
- cs65
Old Apr 9, 2008 | 05:01 PM
rusbukt's Avatar
rusbukt
Added engine pics in gallery. It is one BIG A looking inline.
tmcquaw
28
Sep 6, 2014 08:03 PM
nerksa
May 21, 2013 09:39 PM
Hickfied
Jul 31, 2010 07:36 PM
huckster
Jul 20, 2003 10:09 PM
trouble
Aug 17, 2002 11:41 PM
