Just for fun; curious!
here we go again!!! cant wait for flashman to chime in. makes my friggin day....
SS, you blow me away. you not only have a degree in mechanical engineering, but also and F150 lightning. Do you even realize that if that motor was in a chassis that could haul/tow (rather than compromise between hauling/towing and turning, which it does better than any truck ever) that it could EASILY outpull your 300? Have you even THOUGHT about it? GIMME A ****IN BREAK! those 2v blown 5.4s are torque MONSTERS. dont EVEN give me the "well, at low rpm" BS because its just not true. that lightning motor will pull harder, stronger, rev faster, and get the job done better than ANY stock 300. go ahead and throw the "mod for mod" argument. Thatll fail too, since the lightning motor can easily eclipse 500-600 lb-ft of torque without so much as removing the head. The one and ONLY argument for 300s (AS ITS ALWAYS BEEN) has been torque per dollar. if you need to pull tree stumps out of the ground for $100, the 300 is the best choice. The difference? You paid more for you lightning. Thats it. Its just as reliable, too. taxi cabs and police cars, boys, taxi cabs and police cars. The modulars are reliable as hell.
Once again, not bashing the 300, just syaing that its only usefulness/awesomeness is its bang for the buck. Just saying that there ARE better things out there. And im blown away that you have a lightning and a 300 and claim the 300 is the best thing ever. Youre already going WAY over the GVWR of the 300 truck, towing 11k pounds. Did you try it with you lightning? I BET NOT
Which would be better, i wonder? The one that makes 270 rwtq, or 380? hmmm.....
flamesuit on...
it just makes me mad, i guess, when people run their mouth off about any motor other than the 300. Sure its the 300 forum, but i dont think that gives people the right to leave fact at the door. its a great motor, im just tired of the hype.
Well by this reasonibg here you are saying a 300 has more torque.Show me the numbers.
I asked here the other day what kind of numbers an all out max effort 300 would make the answer i got was the best ever seen was 500 ft lbs.460 will do that almost stock
What is considered a "high performance 300"? 210 hp?
The only reason all of you are sorry you jumped in on this is because someone called bs on you and you cant back it up with any fact at all.
I said a MAX effort 300 might make 500 ft lb.Max effort means more than just a few modifications.
I cant find any factory torque numbers for a 300.Does anybody know what the best factory number they ever put out was?You might have a leg to stand on if you take the 300s best against the 460 smog eras worst,i will give you that.But if you take the 460s best you are done.
Karl you said that horsepower is what makes you go fast and torque is what pulls.And that the 300 will pull!Well show me the big huge torque number that proves that.I agree that it is good for what it is,you guys cant seem to get that thru your head.Has a stock 300 ever made 1 ft lb of torque per cubic inch?What im saying based on your comment if torque pulls theen the 460 is way way more of a puller than the 300.
460 for the same year is 400 ft lbs@2200.I guess that 200 rpm difference make the 300 a low end torque machine and the 460 a high end screamer huh.Now if we want to go back to the early model 460 i can really blow your theorys out of the water.
What i found real funny was that alot of years the 351 made alot more torque at a lower rpm than the 300 did.Not every year but some of them.Your torque theory on the 300 is bunk,prove me wrong.
Somebody please explain this torque monster thing,the puller of all pullers the 300 I6.Kinda hard to do when the facts are brought out huh?
The reason Ford put 300s in one tons is they have to have a base model.Yeah it will physically move the truck.But it dont pull any real weight.Lokk at the GVW on a 300 equipped 1 ton sometime.
Ive had 4 300s and probably the best ive ever done on mileage was 16 in a 2wd and 12-14 in a 4x4 the 2wds had 3.08 gears and the 4x4s had 3.55s.Now my 460 will get12-14 with 4.10 gears at 55 now you get to 70-75 it drops way down.Im not arguing mileage but it can be closer than most of you will admit
Ive listened to this bs my whole life that the 300 is a great puller.That it will pull with most any V8.Ive owned the trucks,they wont.Ive yet to see anyone who can prove me wrong,all anybody can do is talk.
Does anybody here actually have a "high performance" 300? Id be real interested in someone that really knew what they were talking about.Not well my buddy has one or my dad had one one time.Id be real interested in what a streetable pump gas 300 can really do.
