Ccv Mod Maybe Problems
Old Apr 8, 2008 | 11:18 AM
WHT00EX's Avatar
WHT00EX
I have a 2000 excursion with a 7.3 with 160,000 miles on it. I recently did the ccv mod and I have a good amount of blue smoke coming out of the vent tube when the truck is warmed up and idling. Is this normal?
Old Apr 8, 2008 | 11:23 AM
nhill2090's Avatar
nhill2090
this is normal..its is engine blow by that is usually rerouted into the intake
how much smoke are we talking? possibly get a video up?
Old Apr 8, 2008 | 11:33 AM
F250_'s Avatar
F250_
The amount of smoke will vary somewhat between vehicles based on several factors, some of which are below:
- internal wear, which determines the amount of "blowby"
- weight of oil (which affects the thickness of the oil film on internals
- oil manufacturer - affects individual characteristics of oil like 'filming tendency", detergents, etc.
- any potential restriction in CCV line (like a trap, low dip in tube run collecting condensed vapors, etc.)
For example, I used an Amsoil 5w40 synthetic with a 1" straight run of vinyl tubing and a trap in the line and had no smoke. I changed to Schaeffer's 5w40 synthetic, and replaced the trap with a larger one, and now have white smoke all the time. I am told that this smoking issue will diminish as I run a couple more oil changes of Schaeffers through the engine because the Schaeffer detergent package is having a "cleansing effect) inside the engine - something that multiple users of Schaeffers have experienced as they switched to that oil.
WHT00EX's Avatar
WHT00EX
I don't have a camera I'll see if I can borrow one from one of my buddys. It's not like gobs of smoke but it is definately noticable.
Old Apr 8, 2008 | 11:35 AM
WHT00EX's Avatar
WHT00EX
I don't have a trap on mine do you think that would help? I run the oil that the ford dealership sells me.
Old Apr 8, 2008 | 04:09 PM
fbilly420's Avatar
fbilly420
I just ran my hose straight down zip tied away from the the exhaust manifold and the fan turning just blows it away and I dont see or smell it.
Billy
Old Apr 8, 2008 | 08:34 PM
sflem849's Avatar
sflem849
I doubt a trap would help. The trap is there to settle out the oil in the vapor into a liquid again so it doesn't stain your driveway.
There are better oils out there than Motorcraft Dino. Pete's two suggestions are very good oils. I am switching to Rotella Syn from NAPA Syn (Supposedly not diesel rated)
Old Apr 8, 2008 | 11:07 PM
mudmaker's Avatar
mudmaker
Billy
Thats the way mine is as well!
