window seal
Old Apr 8, 2008 | 05:43 AM
custom cabby's Avatar
custom cabby
window seal
i am stripping my whole truck down to the metal and then protecting it a little with gibbs oil to prolong rust attack. my question is, what do i need to do under the windshield seal? i am needing it to obviously seal but i dont want the moisture/rust issue to be 10 times over under the seal being that it would be bare metal................... now that i just confused everybody!
Old Apr 8, 2008 | 07:51 AM
Freightrain's Avatar
Freightrain
You are putting the window back in with no paint on frame? Usually it's all painted, then window installed so that the metal is sealed.
Old Apr 8, 2008 | 08:22 AM
custom cabby
i am just going for something different. i have seen some older rods with stripped down bodies and want to see how it looks when its completely done. i'm thinking i will have to epoxy under the seal to help protect the metal but didnt know if someone else has done this and has any advise
Old Apr 8, 2008 | 01:06 PM
CN Spots's Avatar
CN Spots
At the very least I'd mark the perimeter of the seal and paint within that area once the windshield/seal is removed. If you're leaving the truck bare metal you could paint that area silver and even if some of it showed, I doubt anybody would notice.
Old Apr 8, 2008 | 02:06 PM
Freightrain
How about just clearing the whole thing? A fellow did that here locally with a '40 ******, as it was all original, all steel and very straight(rare). He cleared it and drives it that way. Don't think he uses it daily, but for cruise in's it's a conversation piece.
Old Apr 9, 2008 | 05:38 AM
custom cabby
yea... never really thougth about that. you would think you would have to have a special clear to adhere just like you need a certain primer over top of bare metal.
Old Apr 9, 2008 | 06:19 AM
rhetor's Avatar
rhetor
you do. there are clear coatings that are designed to do just what you're looking for. the trouble is i don't remember the name of them! I do know you can get them in a rattle-can, which may suit your needs better.
Just make sure you stick to one coat or two thin coats, as it will start to look yellowy when it gets thick, over a shiny surface.
Old Apr 9, 2008 | 08:39 AM
blue68f100's Avatar
blue68f100
There are some paints that look like bare steel you can use. I think Eastwood and POR15 have them in their rust protection lines.
Old Apr 9, 2008 | 09:27 AM
custom cabby
i wonder if epoxy primer would be suitable enough under the seal?
Old Apr 9, 2008 | 02:44 PM
blue68f100's Avatar
blue68f100
Epoxy primmer is the only primmer that does not require a top coat to prevent moisture from penetrating. So it would be a great sealer. And you can spray a top coat within the 5-7 day window with out having to scuff it. But if you thing you may want to spray a top coat, spray a 2k primmer over it (different color) so when you sand you do not get into the epoxy primmer.
Tonkatoy77
13
Sep 8, 2014 09:12 PM
raytasch
Jan 24, 2014 05:11 PM
high ho silver
Escape & Escape Hybrid
Mar 19, 2011 09:54 PM
Pokey11
Aug 27, 2009 11:35 PM
