Sponsored by: Kumho
Grinding from wheel
Old Apr 8, 2008 | 12:34 AM
Galen's Avatar
Galen
Grinding from wheel
It's a 94 Bronco with 193k. There is a constant grinding noise coming from the rear driver's side wheel. It corresponds with the rate at which the wheel is moving. Sand? Axel? Bearing? Any ideas?
Thanks
Old Apr 8, 2008 | 02:24 AM
aurgathor's Avatar
aurgathor
Dunno, but you may want to check it out ASAP because if the bearing goes, in the 8.8", it may ruin the axle.
