Brake proportioning valve
Old Apr 7, 2008 | 08:08 PM
BarryMc's Avatar
BarryMc
Doing the disc brake swap on my 66 f100 the parts are from a 76 f100, my question is, how do I adjust the proportioning valve once I get it installed. Thanks, Barry
Old Apr 7, 2008 | 09:43 PM
William's Avatar
William
Stock prop valve is not adjustable. I disassemble and clean them if all is in order just re-install.
Old Apr 7, 2008 | 09:57 PM
BarryMc's Avatar
BarryMc
The prop valve was working fine when removed, should I dissasemble or leave it alone?
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Barrymc
Sometimes you may have to pump the brake pedal alot of times after bleeding
real good, getting all the air out, then they will ( reset )there self! sometimes
some of them are stuburn!
Wally Womack
Old Apr 7, 2008 | 10:12 PM
BarryMc's Avatar
BarryMc
great, sounds good. thanks
