removing pistons without pulling the engine?
Old Apr 7, 2008 | 07:09 PM
pdalbright's Avatar
pdalbright
I have a 5.4 99 expedition that has a broken piston. I discovered it after pulling the head. Can you remove the piston without pulling the engine? If so what about getting the new one in? any advice?
Old Apr 8, 2008 | 09:47 PM
Ryan50hrl's Avatar
Ryan50hrl
um....no....i think you're going to have to pull the engine...plus the broken piston probably damaged the cylinder or the valves....best to pull it and check everything out
Old Apr 8, 2008 | 10:28 PM
85e150's Avatar
85e150
Can you pull the pan with the motor in? Can you get it back on with the motor in? If so, you're in luck...sort of..
78f250lj
Sep 1, 2016 06:38 PM
Colt.S.
Sep 21, 2015 02:23 PM
MBDiagMan
15
Oct 7, 2008 12:44 PM
tdford
15
Feb 12, 2005 09:47 PM
Purely Ford
18
Nov 24, 2004 12:46 AM
