"new" Tac-Lock ?s
Old Apr 7, 2008 | 09:57 AM
63redtudor's Avatar
63redtudor
"new" Tac-Lock ?s
I have a 9" from an early '80s F150 I want to eventually put under my '84 (currently a 8.8 ). The nine inch currently is an open carrier with 2.75 gears in it. I want to change the gears to 3.50 & install a Trac-Loc. I now have both the gears & trac-loc. Both are used & seem to be in decent shape.
Is there anything in particular I should look for on the trac-loc assembly?
I don't have the bolts to hold the gear to the trac-loc assembly, do I need something special, or will regular grade-8 bolts work fine?
I do have a manual & access to tools, but I haven't worked on a rear end before & am open to recomdations/advice. Thanks.
Edwin
Old Apr 7, 2008 | 12:24 PM
subs1000w's Avatar
subs1000w
i would rebiuld the traclock
Old Apr 7, 2008 | 02:58 PM
85e150's Avatar
85e150
If you haven't done a diff before, I recommend using a shop.
Here for parts, they sell them or you'll know what to look for. As for regular grade 8s, the heads might be too tall....
Currie Enterprises Racing Rear End Categories
Spline count in your carrier match the axles?
Old Apr 7, 2008 | 05:32 PM
76 F-150 390FE's Avatar
76 F-150 390FE
9" T/L Ring Gear Bolts/Washers
thats what you want for the bolts
