03 exp clunk after startup
Old Apr 7, 2008 | 09:00 AM
428fourby's Avatar
428fourby
Hi, My 03 Explorer 4.0l, A/t, makes a weird clunk just after it starts.It almost feels like in the tranny, but everthing else drives and runs normal. Has anyone else experienced this?
Thanks
Old Apr 19, 2008 | 06:51 PM
ShouldaBoughtAToyota's Avatar
My '03 4.0 a/t used to shudder when first put into gear after not using the truck for over 24 hours. The whole truck would shudder and I'd get a very loud clunk. I had to leave the truck with my dealer overnight in order for it to be diagnosed. They had to reprogram the engine computer in order to solve the problem. I hope this helps.
Old Apr 25, 2008 | 08:47 AM
osheam's Avatar
osheam
How long ago did you have the the computer (PCM) reprogrammed?
Old Apr 25, 2008 | 07:51 PM
I had the service done back in '03 a couple of months after I bought the truck.
Old Apr 25, 2008 | 10:53 PM
david53ford's Avatar
david53ford
check make a/c is off remember a/c is on in most modes except panel. If a/c is on you could be hearing in it kick in it is normal on cold start when a/c is on due to head pressure in the compressor.
Old Apr 26, 2008 | 08:13 AM
428fourby's Avatar
428fourby
Never thought of that, i'll try turning A/C off.
Thanks
