5.4 vs 351
Old Apr 6, 2008 | 09:59 PM
tjthegreat's Avatar
tjthegreat
5.4 vs 351
my dad has a 01 f-150.i heard somewhere that some of the earliers 5.4s were 2 valve.can anyone tell me if this is true.I plan on taking his truck tommorow and doin a little racing.Can anyone tell me my chances of winning against a 351
Old Apr 6, 2008 | 10:07 PM
LxMan1's Avatar
LxMan1
It is a 260hp 2V engine.
The race will come down to traction, and weight of each truck.
Old Apr 9, 2008 | 02:30 AM
ReAX's Avatar
ReAX
How did it turn out?
I'd suspect the 351 had the advantage off the line, but if the race was long enough the 5.4 would reach it's power range. At least mine doesn't seem to like running under 2k RPMs, is a scalded dog at 3k.
Old Apr 9, 2008 | 09:41 AM
tjthegreat's Avatar
tjthegreat
well hes still in florida so it will pry happen next week ill let u guys kno tho
Old Apr 16, 2008 | 09:39 PM
Big Bad's Avatar
Big Bad
Too many unknown variables. Stock to stock and of comparable configuration, the 5.4 will rape the 351.
Old Apr 16, 2008 | 09:43 PM
LxMan1's Avatar
LxMan1
Mines the same way, even with a tuner. It really wakes up around 2500rpm.
I guess I need 4.10 gears!!
Old Apr 17, 2008 | 11:23 AM
tjthegreat's Avatar
tjthegreat
does any1 kno the specs for the 351 right before they quit making them i believe the 5.4 is 260hp and 350Ibs
Old Apr 17, 2008 | 11:31 AM
Big Bad's Avatar
Big Bad
210 HP, 328 LB-FT.
The 94/95 Lightning 5.8, which came with GT40 heads, tubular GT40 intake manifold, and a "marine" cam made 240 HP and 340 LB-FT.
Old Apr 17, 2008 | 02:04 PM
ReAX's Avatar
ReAX
I have 4.56 gears (and 35" tires) and I still think my old 300I6 with 4spd granny would take it off the line in second gear (first wound out at 15mph with the 3.55 gears and 31" tires).
Old Apr 17, 2008 | 02:14 PM
Big Bad's Avatar
Big Bad
I believe that. It's all gearing, the 4R100s 2.71:1 first gear isn't much help in getting all that mass moving.
The catch is, the I6/M5 would also eat a 351/4A's lunch out of the hole up until 30 mph or so.
david_351
Engine Swaps
Aug 7, 2010 11:33 PM
rjobe07
Jul 31, 2010 04:45 PM
ak49er
2004 - 2008 F150
Jan 18, 2010 06:17 PM
stutterstan
Modular V8 (4.6L, 5.4L)
Aug 18, 2007 01:11 PM
dlwhitehead65
General Automotive Discussion
21
Mar 10, 2006 07:11 PM
