f-350 with 460 problems please help
Old Apr 6, 2008 | 11:40 AM
codys50ford's Avatar
codys50ford
My F-350 has been running verry bad for a while now. Problems like when i accelerate the engine seems to almost be cutting out but its still running. I have nearly no power when it does this and it just seems as if it is not getting enough gas or it is just running on less than 8 cylinders. So i change all eight injectors thinking it is this because the truck has some miles on it, and nothing not a change in anything. I am in desperate need of some advice seeing as i dont have time to troubleshoot. I checked the fuel pressure and it seems to be fine...(what is the recommmeded fuel pressure for this engine?). I wonder if it is the throttle position sensor...but and still not sure. PLEASE anyone with any advice please help.
Old Apr 6, 2008 | 07:17 PM
codys50ford
bump, really need help
Old Apr 7, 2008 | 12:48 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Have you pulled the codes, if so what did you get? I would start by pulling the codes. Since you have checked for fuel issues, I would also check out your distrbutor cap, rotor, plug wires, and plugs. My 351 started cutting out and had no power, much like you are describing, it was a bad cap and rotor.
