General Diesel Discussion
Does diesel brand matter?
Old Apr 6, 2008 | 12:58 AM
Zane_Greyhound's Avatar
Zane_Greyhound
Question Does diesel brand matter?
I posted this question on SeattleGasPrices.com and received conflicting responses. Does it matter where I buy my diesel? I was informed by an oil and lube shop that I should be buying my diesel from Shell, but I don't think it makes any difference if I buy from Shell or 76 or Safeway or whoever, as long as it's diesel, right? Are there different grades? Better additives? I'm new to diesel engines, so help would be appreciated!
Old Apr 6, 2008 | 06:23 AM
884x4broncoII's Avatar
884x4broncoII
i dont think brand matters too much, i always try to get my fuel from high volume stations like truckstops to insure that the fuel is fresh
Old Apr 6, 2008 | 06:39 AM
JOE-M's Avatar
JOE-M
I do think it matters. I buy Exxon from a station (it's a nickle a gallon less than the other stations) and it consistently gets 1/2 miles per gallon less. If I buy it from Kroger It gets 1/2 - 1 mpg more and has more pep and power. I don't think the brand matters as much as which station you get it from (different tanks at the tank farm maybe). Find you a station that sells a lot of fuel so it is fresh, your truck runs good on the fuel, and the mileage is what you think it should be (it will never be high enough for me). The only way I know to do it is try a couple of tanks from different places until you find one you like. I've never found that the brand or brand name really matters.
Joe
Old Apr 6, 2008 | 07:51 AM
NJF350SD's Avatar
NJF350SD
I agree 100%
Old Apr 6, 2008 | 08:34 AM
tex25025's Avatar
tex25025
I do have my favorites as do most people, but at one time I had heard that you should get it at various different places in order to make sure that you don't get an overly contaminated tank of fuel(which isn't needed if you go to high turnover volume places, but I have to drive a little to far for that piece of mind) which is what I end up doing most of the time as I do travel fairly frequently.
Old Apr 6, 2008 | 08:43 AM
origcharger's Avatar
origcharger
I think it depends on the station, volume sold and the fuel supply network in the area. For instance, in my rural Iowa area there is a pipeline terminal nearby, almost every retail outlet and tank truck operator, no matter the brand gets their "generic" fuel from there.
We get our fuel delivered in bulk from the local BP Jobber, all his fuel is trucked up from the BP terminal in Des Moines, he does not deliver any fuel to the BP stations in town.
I will also say BP has a "Premier" branded premium diesel fuel available and if you can get it, its very good.
Old Apr 6, 2008 | 02:08 PM
stormyrider's Avatar
stormyrider
What matters most is the owner taking care of his tanks to keep moisture out and not allow any mold growth to occur. Stations that move a lot of fuel have less of a chance for mold growth but can still get moisture.
Old Apr 6, 2008 | 05:40 PM
scottman70's Avatar
scottman70
Yup Yup, couldn't have said it any better!
Old Apr 6, 2008 | 08:11 PM
stickittoem's Avatar
stickittoem
i am fairley new to the site, joined about a month ago. i for got how to post a new thread, would you help me out?!?! thanks Scott
Old Apr 6, 2008 | 08:30 PM
IDMooseMan's Avatar
IDMooseMan
You'll find "New Thread" at the top of the listings. Click on that, enter a Title, and type away. Click to post the topic and you should be in business.
Old Apr 6, 2008 | 08:46 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
With fuels. The higher the cetane rating the better the diesel will perform. I run premium fuels whenever I can and notice a difference and the cost is about .02 difference.
Old Apr 6, 2008 | 09:05 PM
scottman70's Avatar
scottman70
What JDMOOSE said...........
Old Apr 6, 2008 | 10:30 PM
randomhero1172's Avatar
randomhero1172
theres been a rumor flying around for the last year or so about premium diesel (like premium unleaded) but i have yet to see it. this would be 2 diesel selections at one pump. One being a higher cetane (also probably a higher price ). So...whats this Premier fuel that they are selling?
higher cetane? Or just some labeling BS - alot of places put premium or some sort of catch word just to make you think its higher quality. Im pretty sure all diesel is basically made by the same process so the cetane doesn't vary that much, it may drop if its old or other containments are in it.
Old Apr 7, 2008 | 10:12 AM
wwb's Avatar
wwb
Add some DK for the cetane boost and some Opti-Lube XPD for pump & injector lube, and you have better than your "premium" diesel.... plus, you control how much of each has been added.
And it's cheaper for you to do it yourself.
Old Apr 7, 2008 | 07:00 PM
stormyrider
Around here most stations only have one pump and what is sold as premium is a blend of #1 & #2, the ratio of which changes with the seasons. I get #2 at the farm because I have a storage tank. #2 has more BTU's then #1 or blends so you use less of it. It also has a higher parrifin concentration so will gell in the winter if not treated.
