Amplifier and woofer placement
Old Apr 5, 2008 | 09:41 PM
workingdog's Avatar
workingdog
Does anyone have the 6.5" bazooka behind the seat (gas tank removed)? I know the 8" won't fit.
And, people talk about mounting amp's under the seat, but what do you do about the cable that connects the two seat mounting rails? Can it be pulled up out of the way somehow? Or is there a way to mount against the back of the cab without putting holes through the cab to the exterior?
Peter
Old Apr 6, 2008 | 10:23 AM
rhetor's Avatar
rhetor
In the past i have glued small 3/4" plywood blocks to the sheetmetal, and then secured the amps to those blocks with screws. I like to do this if there is room if i can, for additional cooling. Works great to keep from putting holes into the sheetmetal, and you can pop off the blocks later with a flat head screw driver and a few taps of a hammer.
I've done several amps like this, horizontal or vertical, i've never had one fall off.
1"x1.5" at each corner is plenty of surface area for silicone to hold the amp.
Old Apr 6, 2008 | 11:55 AM
workingdog's Avatar
workingdog
That's a great idea. What are you using for glue - just silicone?
Peter
Old Apr 6, 2008 | 12:25 PM
rhetor's Avatar
rhetor
silicone works great, so does construction adhesive (liquid nails)
I would recomend silicone adhesive. Comes in a bunch of colors, works great. The best part about it is that it gives an excellent strength, but when you remove it, it doesn't rip apart the material.
For the bass tube- I wouldn't recomend those. I never liked the way they sounded. I've had better luck using a free air woofer or a shallow design woofer in a shallow box.
Depending on what kind of music you listen to, going over 10" for a sub is usually pointless. An 8" will give you great sound for all kinds of music. I listen to classic rock, blues, jazz, etc. A good sub in an 8" size works great.
6.5" sized subs- why not just get 6.5" radial woofers with crossovers and put them in the doors or kick panels?
