Decoding
Old Apr 5, 2008 | 08:44 PM
gangstakr's Avatar
gangstakr
Decoding
Ok guy's need help identifying the following.
F25CR482257
W.B. 128
Color B
Model F250
Body C81
Trans G
Axle B4
Old Apr 5, 2008 | 09:07 PM
Customcab's Avatar
Customcab
Here's what i can decode;
F25 = F250 2wd
C= 292 4v 153hp 3800rpm
R= San Jose assembly plant
wb128 = lwb
Color b = Turquoise
Body C81= need additional letter to determine Standard or customcab.
Trans G= 3spd Cruisomatic
Axle B4= 4:56 ratio
Hope this helps.
Mitch
Old Apr 5, 2008 | 09:55 PM
gangstakr's Avatar
gangstakr
It was a Custom Cab Any idea on exact year? It has to be 64 or so I think. The scuff plates are those from a 64 This truck had a Dash pad on it and the Custom Cab plate under dash Bezel.
Thanks Customcab
Old Apr 7, 2008 | 08:58 AM
airharley's Avatar
airharley
According to the site VIN Decoder it's a 63. I'll check the manual and see what it says.
Old Apr 7, 2008 | 10:42 PM
gangstakr's Avatar
gangstakr
I was able to determine November 1963 So does that make it a 64 Model?
Old Apr 8, 2008 | 01:24 AM
BensDaddy's Avatar
BensDaddy
I'd say it is, you could get in touch with Ford, I got most of my vehicle info from them in addition to the great information NumberDummy was able to give me here. Incidently has anyone seen hom lately?
Old Apr 8, 2008 | 02:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F25CR482257
482257 = 1964
1964 Serial Number Range: 445,001 thru 580,000
When the first digit of the body code is a letter, it's a Custom Cab
C = Medium Green Crush Vinyl & Medium Green Check Pattern Woven Plastic.
81 = 81B Custom Cab
When the first digit of the AXLE code is a letter, it's a Limited Slip rear axle.
B4: Spicer-Dana 60 / 4.56-1 / Limited Slip / 5200 lbs. Rear Axle Capacity.
