Truck not sitting level
Old Apr 5, 2008 | 06:07 PM
Charles in Lorette's Avatar
Charles in Lorette
Just got this '04 F-150 Supercrew about a month ago. I recently noticed that it didn't look like it was sitting level from drivers to passenger side. So I parked it on level ground (paved driveway), filled the tires with the same amount of air and took some measurements. From the ground to the top of each tire, both front and rear on passenger side are 1/2" higher than drivers side. From ground to top of wheel wells, passenger side is higher than drivers side by 1".
What's going on?? It doesn't look like there was/is a lift kit or modifications to the suspension.
Old Apr 5, 2008 | 06:20 PM
Trevor1's Avatar
Trevor1
you may have a blown shock or a weak coil spring
Old Apr 5, 2008 | 08:02 PM
F0rdzTuff's Avatar
F0rdzTuff
I agree with Trevor on this one...I had a Sport-Trac that did the same thing, and the spring was shot, and not from my 220lb *** sitting on it moreso than my wife's 105lb *** sitting in the passenger seat. UNACCEPTABLE in an F150. Mine is level. Talk to your dealer.
Old Apr 5, 2008 | 08:15 PM
efx4's Avatar
efx4
Good point, but also make sure it was never in a wreak where there could possible be some hidden damage.
Rob89
May 27, 2022 01:38 PM
fordman19762003
2009 - 2014 F150
Jul 7, 2016 07:55 AM
Dorsai
13
May 25, 2016 08:07 AM
AAPatten
Nov 30, 2011 06:02 PM
Enomra
Apr 10, 2007 10:14 AM
