98 Expedition
Old Apr 4, 2008 | 08:34 PM
tafy5's Avatar
tafy5
98 Expedition
If the starter or starter relay goes out will it give an OBD code?
Old Apr 4, 2008 | 10:23 PM
sbclemens's Avatar
sbclemens
I looked from P0102 through P1900 and did not find a code for the starting system.
Old Apr 5, 2008 | 03:13 AM
tafy5's Avatar
tafy5
Starting problem
I just came back and 30 minutes later I went to leave again and the Expy wont turn over just a load click from the firewall area behind the battery. Maybe the relay? The check engine light is on too.
Old Apr 5, 2008 | 03:15 AM
tafy5's Avatar
tafy5
Correction
A loud click from the firewall area behind the battery.
Old Apr 5, 2008 | 06:01 AM
Gevans17's Avatar
Gevans17
wont start
Loud "click" at firewall is the relay closing. Are your terminals clean? How old is your battery?
Old Apr 5, 2008 | 06:26 AM
aba4430's Avatar
aba4430
Agree with questioning the battery.
Old Apr 5, 2008 | 09:17 AM
tafy5's Avatar
tafy5
Re:Battery
Yes the battery is good, even with a jump start it would not turn over.
Old Apr 5, 2008 | 09:20 AM
sbclemens's Avatar
sbclemens
I usually don't get any warning that my battery is going bad. Check and clean the connections. Take the battery to a parts store and they'll test it for you. If the battery is good, jump the starter relay and the starter should turn. If it doesn't, then you have a bad relay. But the "clicking" indicates that the relay is probably ok.
Old Apr 5, 2008 | 06:17 PM
projectSHO89's Avatar
projectSHO89
Since a jump didn't make a difference, it the battery.
Here's your choices:
1) Starter motor
2) Cable to starter motor
3) Once of the accessories driven by the serpentine belt has frozen. Remove serpentine belt and see if it cranks.
4) The engine is locked up.
I just went through this on my 97 F150. The A/C clutch bearing imploded and locked the clutch, keeping the whole engine from cranking. Removing the serpentine belt was key to diagnosing it.
Steve
..and, no, there are no OBD codes for this event.
Old Apr 5, 2008 | 10:30 PM
Gevans17's Avatar
Gevans17
Pull that starter and have it bench tested. I fit is bad, suggest you buy a new one and not rebuilt.
Old Apr 6, 2008 | 08:44 AM
Phil056's Avatar
Phil056
Mine decided to quit one day without warning (it had the same symptoms as you describe). I had to have it replaced, then everything went back to normal. good luck
