429 or 460
Old Apr 4, 2008 | 07:47 PM
jb65542's Avatar
jb65542
429 or 460
how do you tell the difference between the 429 and the 460
thanks for any info
Old Apr 4, 2008 | 08:19 PM
jade79's Avatar
jade79
I believe the blocks are the same, the stroke (crank) is different. As far as I know, the only way to tell would be to pull the oil pan and check the casting # on the crank. If it begins with 2Y or 3Y it should be a 460. If it begins with 4U it's probably a 429. Here's a good website to double check 460ford.com :: Index.
Old Apr 4, 2008 | 09:39 PM
Bear 45/70's Avatar
Bear 45/70
Crank and pistons are all that is different.
Old Apr 5, 2008 | 07:30 AM
jb65542's Avatar
jb65542
thanks guys i will try to look this week
