67 heater question.
Old Apr 4, 2008 | 07:36 PM
Old Ford Blue's Avatar
Old Ford Blue
67 heater question.
Well, I just got my new)to me) 67 F-100 ranger home. My first question is about the heater\defroster. It has a brand new blower and all that stuff, but it dosen't blow much of any air, and there is none at the defrost vents, wheather you pull(like it says) or push.
I was also wondering wheather you pull for heat or push in for heat?
Thanks guys! I'm already lovin this truck, and I wish it weren't raining as I'd be out there cleanin her up.
Old Apr 4, 2008 | 08:57 PM
f2501967's Avatar
f2501967
you pull for heat, first turn to the right puts the blower on hi, second turn puts blower on low.
check to make sure the vents are not clogged with any debris or anything else. and double check to make sure the vents are connected. also check to make sure all the linkage is connected and not stuck in off position
Old Apr 4, 2008 | 09:33 PM
Old Ford Blue
Hey thanks! I figured out the blower, and checked all the vents and ducting, which was in good shape and all hooked up. The trick I was missing was just what you said, "pull for heat". But not the middle ****, which is what I thought. Gotta pull the blower **** as well. Thanks!!
I love this truck:-)
