1993 AOD shift problem
Old Apr 4, 2008 | 04:36 PM
smithwesson29's Avatar
smithwesson29
1993 F150 4WD, 302 with AOD, 120,000 miles, everything original, including the owner. Trans filter changed frequently. Last night shifter felt strange, and was difficult to shift in one direction - the direction toward Park. Today the shifter feels strange and will not go into Park whatsoever. There is likely something I should have been lubricating over the years that has now failed. I am digging out my Haynes. Any advice would be very much appreciated.
Old Apr 4, 2008 | 06:23 PM
Trevor1's Avatar
Trevor1
aluminum steering shaft probably broke that sits on top of the steering column that is if the shifter feels sloppy or it could be the park pall inside the transmission
Old Apr 4, 2008 | 09:24 PM
Dukernc's Avatar
Dukernc
Have you looked underneath to see if by chance something might have gotten lodged up in the linkage area? I noticed that your F150 was a 4X4. This happened to me once and it turned out to be a branch that had gotten caught up in the linkage. Good luck!
Old Apr 5, 2008 | 05:46 PM
smithwesson29
Yes, thanks. There is nothing I can see external to the transmission that looks out of place or broken. Now that I have time I will drop the pan and see if anything there looks peculiar. Maybe there will be pieces in the pan; I still remember scratching my head over the filler tube plug that I found 15 years ago the first time I changed the transmission filter.
Old Apr 5, 2008 | 10:31 PM
88CougarCoupe's Avatar
88CougarCoupe
"still remember scratching my head over the filler tube plug that I found 15 years ago the first time I changed the transmission filter."
Your not the only one. they are all like that I found out later. me and my brother were both like WTF? guss it was never serviced the 80k miles till we changed the fluid. ended up lasting alot longer too and from one car to another. till the Now c4 is in my car.
Old Apr 5, 2008 | 10:36 PM
lv2race's Avatar
lv2race
Try adjusting your neutral safety switch to spec.
hch60
Dec 27, 2014 11:33 AM
TJ62
Nov 29, 2014 11:23 PM
firefox9
Mar 30, 2011 04:13 AM
Poison Oil Racing
Jul 14, 2009 02:07 PM
