302 EFI choke
Old Apr 4, 2008 | 06:01 AM
86F150302's Avatar
86F150302
302 EFI choke
Is there a way to adjust the choke on an EFI 302? I live in Florida and really don't need it plus when its on it idles at 2k rpms for awhile until it finally turns off. Even when the trucks warn the choke still comes on.
Old Apr 4, 2008 | 06:20 AM
netscaner's Avatar
netscaner
You don't have a choke on an EFI system.
What you have is a computer controlled enrichment system utilizing the injectors.
The computer uses input from several sources for this and the main one is the temp sensor.
The choke action can be overridden (injectors shutdown) by holding gas pedal to the floor.
Old Apr 4, 2008 | 07:43 AM
Conanski's Avatar
Conanski
That's not entirely accurate. Before the engine starts if you hold the pedel to the floor the injectors are shut off, this allows the motor to clear a partial flood condition. But once the motor starts holding the pedal to the floor results in maximum engine rpm.. not what you want.
The cold start routine of the SD EFI system cannot be circumvented, it's hard programmed into the computer.
Old Apr 4, 2008 | 08:14 AM
netscaner's Avatar
netscaner
HOLDING PEDAL TO FLOOR CAUSES MAXIMUM ENGINE RPM AFTER ENGINE IS STARTED
That's kinda a given isn't it ?????????..............LOL
I'm sure he realizes it is only while cranking......................and his truck is a 96 which wouldn't be SD EFI
Old Apr 4, 2008 | 08:40 AM
Conanski's Avatar
Conanski
It didn't read that way to me.. hence my post. You never know what people are thinking....
I'll let you look at the first line in the OP's signature again.
Old Apr 4, 2008 | 10:59 AM
quicklook2's Avatar
quicklook2
that's the truth!
Old Apr 4, 2008 | 04:16 PM
netscaner's Avatar
netscaner
WOOPS................I guess 86 ain't 96.........LOL
Didn't expect 86 in 87-96's
Old Apr 4, 2008 | 06:06 PM
86F150302's Avatar
86F150302
Well the reason im here with an 86 is because people in the 80-86 mostly know about carb trucks since 86 was the 1st year of the EFI.
Old Apr 4, 2008 | 07:27 PM
netscaner's Avatar
netscaner
Well, you're welcome to be here 86.
Have you checked the temp sensor or the wiring to it ??
Old Apr 4, 2008 | 07:59 PM
bluesman2333's Avatar
bluesman2333
You can do a few things to make it rev down sooner, but as has been already stated, it is a computer gig. Try the temp sensor circuit as stated above but it prolly is OK as it revs down as it warms up. You can try setting the base idle with TPS unplugged to the sticker RPM warm, then probe the TPS wiring (hot engine running at idle, TPS plugged in) to see if you have about .96 volts on two of the wires at idle. (The other two combinations will be well over that) Turn the TPS until you have that value. You might need to futz with the holes in the ears to allow movement. Other than that, the only other thing you could do is possibly substitute a different sensor or if it is analogue, put a resistor in parallel. I think it is digital though, meaning it is a switch not a variable resistance. You might find a vacuum leak or two affecting this and possibly a stuck open thermostat.
jbonilla77
Jul 29, 2016 11:29 PM
pugetsoundsailer
Jul 7, 2016 02:34 PM
mike_black
32
Nov 25, 2015 07:01 PM
Smalltownboy
Apr 14, 2015 11:56 PM
Big-Dawg
Jun 9, 2014 04:29 PM
