Hey guys I have a 1979 f250 4x4 with a 351m and a c6 tranny. Does anyone know where the vin is stamped on the engine and tranny? I'd like to locate them to see if everything is original. If so I might do a total restoration on her. Thanks
The engines have casting codes
the transmission have ID Tags
The Truck frame is stamped on the passenger side frame rail, between the firewall and rad support ..and again under the cab same side
There is a buck tag riveted to the top of firewall and hung by some wire between the cab and box under the truck
hello again, the door post sticker shows
front 3500#
rear 4600#
id# f26hceg3309
the bottom line is blank but in the lower right corner it has fo110 and to923
the door plate shows wb 133"
color d but that has been changed
type f264
body da4
trans k
axles b4 and under that a1
i know it has a dana 44-9f front axle and a dana 60 rear axle, i would like to determine how much of the equipment is original. thanks
