Sponsored by: Real Truck
front end question????
Old Apr 3, 2008 | 06:02 PM
foolforfords's Avatar
foolforfords
hello all , just wandering if the leveling kits are easy too install, my o5 350 cc seems to sit alot higher in the rear end.then the front does. is that normal .are all the leveling kits the same hight or should I look into a lift kit ? any thoughts would be appriciated . FFF
Old Apr 3, 2008 | 10:53 PM
3000 FPS's Avatar
3000 FPS
It is normal for the 350 to sit higher in the rear because they use a higher block on it than what comes on the 250. As far as lifting your truck it is just a matter of preference. I know some who have just done the leveling kit to get the front end up. It usually means replacing the coils so be prepared for that.
Old Apr 3, 2008 | 11:37 PM
rollerstud98's Avatar
rollerstud98
also if you tow a lot and tow heavy, your truck will look like its sagging real bad with a leveling kit on
Old Apr 18, 2008 | 09:09 AM
Saskguy21's Avatar
Saskguy21
leveling kit
I just had a Ready-Lift spacer kit kit put in my 05 f350 cc. all it is, is a set of spacers that go in on top of your coils but the trac bar has to come off to get at the drivers side. truck looks great now
