Inner Fender Assembly
Old Apr 3, 2008 | 01:10 PM
fordman2267's Avatar
fordman2267
Question Inner Fender Assembly
I bought a used inner fender for my '68 F250. I was checking it over and noticed a putty like substance on the top edge where the fender would be mounted. My question is, do I need to put more of that on there during re-assembly? And where do I purchase that stuff?
Old Apr 3, 2008 | 06:34 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
It's probably seam sealer, you'll want to scrape it all off before you spot weld the new inner on the truck, then go along and put it along the edge. It'll keep water and all the gunk from getting between the panels and causing that lovely scourge called rust.
Old Apr 3, 2008 | 07:51 PM
fordman2267
It was definately under the fender when assembled. It is completely flat and about 3/4" wide. There is no sign of spot welding done to the inner. I thought these just bolted together. The putty must be there to cushion the metal from rubbing together?
Old Apr 3, 2008 | 09:33 PM
daveengelson's Avatar
daveengelson
Have a 65 F100, the inner fender, and fender are assembled together thru a series of nuts and bolts. Believe the material referring to is cauling, used between metal to metal surfaces. There is also seam sealer, each has a particular purpose. There a several sources, may want to check w/ local auto body, auto paint, or auto parts suppliers, posting a few links.
Eastwood Company: Search Results for caulking
MSC Google Search Results
https://www.autobodytoolmart.com/p-10395-12835.aspx
https://www.autobodytoolmart.com/p-10383-12823.aspx
https://www.autobodytoolmart.com/p-10384-12824.aspx
Old Apr 3, 2008 | 10:02 PM
fordman2267
Thumbs up
I appreciate all the help and tips. Thanks Guys
Old Apr 6, 2008 | 06:55 AM
cujo8's Avatar
cujo8
Look into 3M's Strip Caulk, I picked up a box of it at a local automotive parts store that deal in painting supplies.
GreatNorthWoods
13
Mar 18, 2004 03:35 PM
GreatNorthWoods
Apr 6, 2003 08:37 AM
rchassie
Paint & Bodywork
Mar 18, 2003 04:33 PM
rchassie
Mar 4, 2003 10:11 PM
fomocoloco
Sep 29, 2002 04:17 PM
