Steering u joint
Old Apr 3, 2008 | 11:23 AM
coreyws's Avatar
coreyws
Steering u joint
Can anyone tell me where i can get a steering u joint for my 1978 f250 it is the one right after it comes out of the column. Thanks
Old Apr 3, 2008 | 11:28 AM
77f2504by4's Avatar
77f2504by4
i dont know if you can buy just the u joint. the company borgeson makes a new seering shaft for our trucks. google them, i cant remember their website off the top of my head.
Old Apr 3, 2008 | 11:34 AM
coreyws's Avatar
coreyws
I didn't mean the u joint its self the two pieces that go on the shaft also. That whole assembly without the shaft itself.
Old Apr 3, 2008 | 11:46 AM
Mil1ion's Avatar
Mil1ion
He's looking for one of these, that I just happen to have
Old Apr 3, 2008 | 11:59 AM
Thunderjet4x4's Avatar
Thunderjet4x4
Heya Mil1ion-awesome posts btw! I was curious of the pic of your steering shaft, never seen one with what looks to have a slip yoke? for the dentsides. I thought it might be one from a 80's up truck? I wondered if they would work... I also wanted to note that my ol 74' F-100 had an actual small greaseable u-joint right off the column, the joint yokes are welded to the shaft and appears factory. I replaced the greaseable assy. with one from a 76' with the normal style joint and the non-rag coupler? I did keep that odd setup, never seen one again since. One day I will take it apart and see if I can revive it, and hopefully get a digital camera.
Old Apr 3, 2008 | 12:01 PM
Mil1ion's Avatar
Mil1ion
The one shown above is from a 78 4x4
Old Apr 3, 2008 | 01:13 PM
sixkids+4's Avatar
sixkids+4
steering u joint
I would check with Dennis Carpenter Ford parts or Blue Oval truck parts.
Old Apr 3, 2008 | 02:33 PM
tatonka04's Avatar
tatonka04
There is another place I hear guys on here get them from as well. I think that they are all a bit spendy, but, it does give you another possible choice to pick from? They're website is: Flaming River Steering Components. Good luck!
Old Apr 3, 2008 | 02:47 PM
Mil1ion's Avatar
Mil1ion
Jeff's has a complete replacements for $245.00.
Lower Steering Shaft, Power 1978 - 79
Old Apr 5, 2008 | 03:02 PM
Ozman001's Avatar
Ozman001
steering shaft
I'm looking for a the steering shaft that goes from the fire wall to the gear box for a 1977 f250 truck with a 400 2bbl engine. have checked all the local junkyards but no luck. how can i tell if this truck is a "highboy"???
Old Apr 5, 2008 | 03:08 PM
Mil1ion's Avatar
Mil1ion
Ozman, you mean like in Post #4 ?
I have linked to the part in Post #9 and mentioned the one I have in Post #4
Old Apr 5, 2008 | 03:12 PM
Ozman001's Avatar
Ozman001
thanks mil1ion but the lower coupling on the pic you posted is different than mine. my lower shaft is about 23" long. which is why i asked how can i tell if my truck is a highboy
Old Apr 5, 2008 | 03:43 PM
brownfoot's Avatar
brownfoot
sounds like he has the one like on my '76 that has 2 universal joints and not the rag joint on the steering box end
replaced mine with the Flaming River several years ago
Old Apr 5, 2008 | 03:58 PM
77f2504by4's Avatar
77f2504by4
BORGESON U-JOINTS#
this is the one i used on my 77 its bolt in. if you have the short shaft like on 78-79's you have to cut it down.
Dennis, i have NEVER seen that shaft before... I've owned 7, 73-79's and none of them had that shaft. I've also parted out dozens more and none have ever had a shaft like that. is that an f150 part? all the trucks I've had or torn apart were f250's and 350's.
Old Apr 5, 2008 | 04:42 PM
Ozman001's Avatar
Ozman001
Thanks 77f2504by4, that looks pretty dang close to what my steering shaft looks like. Read the FAQ about the highboy and it seems i do not have one. my truck sticker says it was made 08/77 and the vin# is Z08903. Guess the old girl is gonna have to wait till next payday to get fixed. The steering is REAL loose in her, about 1/4 turn worth of play at the steering wheel.
