the one in my dash is still on...I cant figure it out still.... I have replaced my vacuum pump, bled out all my brakes, checked to see if the wires were connected on the proporting valve and the E-Brakes...
I do have the E-Brake pedal held up with wire because I don't have any cables installed. Would that do it even though the pedal is all the way up?
I'm about to just freeging take that little light bulb out!!!
Disconnect the purple wire from the ebrake and the proportioning valve one at a time and see if the light goes off. Both work by grounding the wire, so there could be fault in either switch. If the light goes off after you disconnect either, you can reset your proportioning valve or replace the ebrake switch. Diesels also have a low vacuum warning switch...I believe it's located in the passenger side fender well. I'm not positive that's tied into the brake warning light circuit, but you might want to check that switch also.
You know I never thought about that being the problem. I have taken the vacuum line off it before but it didn't do anything, ill go do some searching and trial and error tomorrow.
Well I have revisited this dash brake light staying on.
I am thinking more and more it has to do with the cruise control wiring. I have since then cut the hose off the brake pedal, What else under the dash needs taken out, to do away with all the cruise stuff?
Will a bad cruise control make the light come on? and also will it make it stay on after removing all the cruise control items?
I have installed new emergency brake cables from the back all the way to the emergency brake cable.
I also found a vacuum alarm in a junk yard and unplugging it still don't do anything. Is it a bad alarm or what?
Thanks for the help.
If its not any of this its gotta be the proportioning valve.
Remove plug from porportioning valve, if light goes out, reset or replace valve.
Remove wire from parking brake pedal, if light goes out repair as needed parking brake system.
It's a really easy thing to daignose where the problem lies.
Do not disconect or make inoperative the brake warning light. You can be made liable for any accident your truck is involved in, your fault or not, due to a saftey device being made inoperative. Your car insurance can deny payment as well, because you knew the saftey device was disconnected when you drove the vehicle.
Can't figure it out? Hmm...well I can...if it's this > >
D5AZ2B264A .. Low Brake Fluid Warning Light Switch-screws into the proportioning valve.
MSRP: $22.47 / ftepartsguy.com price: $12.13.
This switch, which fits 1980 and later F100/350's & Bronco's, fails on a regular basis and here's why.
The switch is plastic, and over time, develops minute cracks in the threads...when that happens, brake fluid seeps out, the low brake fluid warning light on the dash comes on...and stays on.
Bottom line: replace it. Its had it!
I prolly sold over 1000 of these D5AZ switches at the back parts (shop) counter, and another 1000 + of the previous switches (C8AZ2B264A) used from 1968 thru 1979.
Hmm I never know there was such a thing on it. I emailed Green Sales Co since there just right up the road, online shows they got 10 in stock just gotta see the price they have it for.
Ill get right on replacing it.
Could I suspect the booster going bad?
Ive also noticed the resivor in the master cylinder that goes for the back brakes is all dirty looking compared to the resivor for the front brakes, and my master cylinder is new.
I always recommend GREEN SALES if the parts are obsolete and they have them. I've dealt with Green Sales for nearly 40 years.
Since this part was still available, I didn't check Green Sales' (greensalescompany.com) website.
Ive been dealing with Greens for about 3 years now, Every time I walk in the door there I get great service and they go find things in a beat. The only thing I dont like is that on there site they dont provide prices. They still use those micro things or what ever there called, kind of an old school operation they have....
We still don't know if that is your problem though. Did you unplug the wires from the porportioning valve switch yet? Did the light go out?
Also I don't like the sound of your brake fluid being dirty like it is for your rear brakes. Check the wheel cylinders for leaks, and replace them if nessescery, and flush the bad fluid out of the system. Having bad fluid and leaky wheel cylinders could be why the warning light is on. The warning system could be operating correctly warning you of a problem.
Well Here is another possibility, I took my bed of this evening and came upon a vent hose going to the rear end, someone has the hole plugged with a bolt. Why is that?
Ive never got to the proportioning valve yet, I been trying to rule out things that were easy to get to before going down there to it.
I plan on when I get the extra money to buy all new hardware and calipers for the back end.
That's just the axle vent. Unplug that hose, and leave it open to air.
And yes, you can get your drums turned, as long as they are, and will be after turning, still within the min. thickness stamped on the drums. If turning them drops them below the minimum thickness marked, you will need some new ones.
I FINALLY got back to my brake problem. I did finally unhook the wire to the proportioning valve and the light actually went out! So thats the problem either my valve or the switch, now I am going to try resetting my proportioning valve and see what happens
Your brake warning switch could be functioning properly and warning you of a brake problem. Did you ever find the cause of your dirty brake fluid and soft brakes?
