need help on tire sizes
Old Apr 2, 2008 | 07:58 PM
fords all the way's Avatar
fords all the way
i have a set of 15by 10 in rims i need a good size for the tire to put on it what do yall recomend?
Old Apr 2, 2008 | 08:12 PM
bad96's Avatar
bad96
depends on the truck(4x4 or 2x4) and how much on road or off road drivin
Old Apr 2, 2008 | 08:14 PM
fords all the way
no off roadin like i need to know like what width and stuff mostly street like what sise will fit the best and look good its 2 wheel drive
Old Apr 2, 2008 | 09:12 PM
winfordr's Avatar
winfordr
On my 88, when I went to a larger/wider tire, the fronts rubbed on the radius arm with moderate turns. When I went to 95 stock wheels, the problem almost disappeared. You will need to consider the offset on the wheels and whether the tires will scrub on turns.
As far as matching tire size to wheels, you can find info on tirerack.com or discounttire.com, etc.
Old Apr 3, 2008 | 08:47 AM
TexasGuy001's Avatar
TexasGuy001
For street tires I would put 295 50 15 or 295 60 15 if you can find it. 275 60 15 should be alright, but anything thats not this wide will look like crap on that wide of a rim.
For off road tires you would need at least a 32 11.50 15 or 33 12.50 15
