distributor swap?
Old Apr 2, 2008 | 10:06 AM
camccardell's Avatar
camccardell
distributor swap?
I have been looking for a reason why I am suddenly getting a ckp code on my f150. I have changed it from a 95 to a 96 ecm.
I am sure that the ckp sensor is part of the distributor, and sure enough when I look up tha part number for a 95 it is diffirent for a 96. Ford doesen't know what the diffirence is. I think it might just be the gear. One might be steel and one cast.
Does anyone have any idea on this?
Old Apr 2, 2008 | 10:12 AM
Conanski's Avatar
Conanski
What code are you getting exactly?
FYI..All V8 motors after '94 used roller cams so all distributor gears are steel.
Old Apr 2, 2008 | 12:01 PM
camccardell
P0385 Crankshaft Position Sensor B Circuit Malfunction
Old Apr 2, 2008 | 12:16 PM
Conanski's Avatar
Conanski
You get that code because you don't have crank position sensor.. I bet. That's an OBD2 thing if I'm not mistaken, there is a little sensor down next to the crank pulley on the passenger side.. something you can probably install without too much hastle.
Old Apr 3, 2008 | 07:15 AM
camccardell
ordered it today, will be in tommorrow. No timing ring on the harmonic balancer to activate it though. It should change the code though, if that is what the problem is. $200+ for the balancer w/ ring. Hope it is something else, but I guess we shall see.
Old Apr 5, 2008 | 01:12 PM
camccardell
I got the sensor, but I don't have a pigtail for it. Got a friggin huge box of connectors and don't have this one for some reason. Any idea on where to get it? Still lookin for a balancer with a tone ring too.
Old Apr 5, 2008 | 01:30 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
FYI
Ford has started selling all the motorcraft electrical connectors.
I saw a multi page flipchart the other day....
Here:
MOTORCRAFT® WIRING PIGTAIL KITS FOR FORD, LINCOLN OR MERCURY VEHICLES
Old Apr 8, 2008 | 02:05 PM
camccardell
ok, this little thing is friggin rediculous. I allready paid for the sensor $30 + the pigtail $10 and I soldered it in. Well I still need a balancer $100+ assuming I can find one. I also need to change my timing cover I guess, since there is nowhere to mount this stupid sensor!!! Ok, I am geting extrememly frustrated. I do not want to drop the stupid oil pan to change a timing cover just for a friggin sensor, especially one that I am not 100% sure will fix my problem. For all this time and money I am wondering if I can just disable the thing with a tweecer.
Any info on this?
Old Apr 9, 2008 | 07:35 AM
camccardell
Anyone? Conanski?
Old Apr 9, 2008 | 08:19 AM
Conanski's Avatar
Conanski
The Tweecer will cost you lots more so it's not very cost effective, and you have other options with the OBD2 system(SCT). You should start shopping at a junkyard for these type parts.. save you a fortune.
Old Apr 9, 2008 | 03:11 PM
camccardell
I appreciate you help, but I have been to a ton of junkyards, and not finding much of anthing. Hell a junkyard up here can't keep a vehicle for over 3 weeks, especially with the price of scrap so dang high. What are my other options? I am thinking about getting a tweecer anyway, just for future upgrades among other things, so I was wondering if it would do what I was asking. I see that you have one, so I was hoping you would be able to say "yeah, it's cake" lol.
I looked at the sct website, dosen't look like you can enable or disable ecm features like EGR or rear HEGO. I would like the ability to do that as well. Hell mabye the dealership can do a custom flash.
On a side note, if I am to change my timing cover, I might as well change my timing set and put in a new cam. Any recomendations? I was thinking an x303.
...Still waiting for my miracle, lol
Old Apr 9, 2008 | 06:29 PM
Scndsin's Avatar
Scndsin
Could you make a small "L" bracket & use longer bolts that would bolt to the pan rail & get you in the neighborhood of the balancer in order to hold your sensor?
Old Apr 11, 2008 | 12:34 AM
camccardell
anyone used the sct system? Is it the same thing as a tweecer?
