cheapest lowering options
Old Apr 1, 2008 | 06:44 PM
Ford F1Fool's Avatar
Ford F1Fool
what's the cheapest way to lower a 1986 f150....any suggestions would be greatly appreciated.
Old Apr 1, 2008 | 07:10 PM
uncle.stosh's Avatar
uncle.stosh
2 tons of modified will lower it real nice. Should cost less than a Benjamin too.
Old Apr 1, 2008 | 08:04 PM
Franklin2's Avatar
Franklin2
You have no cheap way to lower the original since you have twin-i-beams. Probably the cheapest would be to cut the old suspension off and use a suspension clip off a car. A lot of work though, and you sort of have to know what you are doing.
Old Apr 1, 2008 | 08:25 PM
Ford F1Fool
thanks Stosh....always quick with the responses.....
I didnt mean cheapest as in not buying the proper parts, I meant cheapest out of the parts available for the customization.
Old Apr 1, 2008 | 08:37 PM
uncle.stosh
I was just busting your chops.
There was just a thread about this the other day. Flip kit in the rear, and dream beams or drop spindles if available up front plus shorter shocks is the only safe way to lower these things.
Back in the old days, they would flip the rear and either cut coils out of the front, or heat them up with a torch and jump on the front end. You got a lowered stance, with the added feature of a shortened travel and a harsh ride.
Old Apr 2, 2008 | 11:23 AM
Sycostang67's Avatar
Sycostang67
...and never having to wear out the outside edges of your front tires.
Old Apr 2, 2008 | 11:40 AM
86F150302's Avatar
86F150302
DJM 5 inch Flip kit for rear $50
DJM Suspension FK3000-5 - DJM Suspension Flip Kits - summitracing.com
Front 3 inch drop DJM dream beams $385
DJM Suspension DB3003-3 - DJM Suspension Dream Beams - summitracing.com
Plus drop shocks (maybe $40 each)
