4.2 missing PO300 code
Old Mar 31, 2008 | 09:33 PM
HSR's Avatar
HSR
After doing some searching I see this is quite a common problem.Under load or hard acceleration my truck misses and the check eng light will flash.Po300 is random/multiple cylinder misfire.I've done plugs/wires/coil pack,both #1 o2 sensors and still does it.I've seen multiple threads with things to try but nobody comes on to say what they found.Any help would be great.That folks is post #1
Steve
Old Mar 31, 2008 | 10:12 PM
BrianA's Avatar
BrianA
Steve,
Glad to have you here. And sorry you are stuck with the 0300 code to start you off.
It is frustrating when we never hear back what folks found - if anything - to solve their problem.
That leaves me, like everyone else, not knowing what you should do.
I really wish I had some good advice, but I don't.
I'm thinking I remember something about the hall effect sensor on the crank being a suspect item, but honestly can't say for sure.
Maybe it was the cam sensor.
I just don't know. Maybe - and I hate to say this - a trip to Ford to have the hook it up to the diagnostic cimputer might be in order.
FWIW, you are certain you got all the plug wires hooked up correctly? It'd be a shame to have fixed one problem and introduced another.
Thanks, and PLEASE let us know what you find.
Old Mar 31, 2008 | 10:29 PM
HSR's Avatar
HSR
I'm sure I got the wires right as it runs like a top all around town,its just when I'm at say 40 mph and go to acc hard but not enuff to kick it down a gear it'll chug.Or when I come to a steep grade and it needs to lug abit it'll chug.Now if a clear to code I can drive er like an ole lady,no sweat,it'll miss the odd time.but if i drive er like an 18yr old boy it'll start to miss and the ch eng light will flash then stay on solid which means its a serious miss.I've searched this site and another ford site and I mean this is a common problem but as I say no answers.Will post my results for sure
Steve
Old Apr 2, 2008 | 09:12 AM
HSR's Avatar
HSR
Well figured it out.Burnt out a set of platinum NGK's in less than 15,000km.Gaps ranged from .070" to .084",driver side bank was the worst.
Steve
Old Apr 2, 2008 | 08:29 PM
BrianA's Avatar
BrianA
AH - I shoulda' thought to ask. Sorry bud.
Use Motorcraft plugs.
But I'm guessing you know that now.
Nice to have you here.
Thanks for the follow-up and do stick around.
cobra870
1983 - 2012 Ranger & B-Series
13
Mar 9, 2023 01:50 PM
pswann64
Modular V8 (4.6L, 5.4L)
30
Aug 21, 2013 11:57 AM
jstewart007
1997 - 2003 F150
May 12, 2008 08:31 PM
flearoy
1997 - 2003 F150
Feb 2, 2006 04:47 PM
97Aerostar
Aerostar
Oct 5, 2003 11:04 PM
