C6 questions.
Old Mar 31, 2008 | 08:37 PM
c.l.nye's Avatar
c.l.nye
Question C6 questions.
are all C6 trannys the same internaly? The reason i ask is,I have a 74 C6 with 4x4 with a FE bolt pattern that is very shot.I also have a 78 4x4 with the 351 bolt pattern that has less than 3000 miles on it. What i want to do is have the cases swaped.
Old Apr 1, 2008 | 02:21 AM
Dirt racer's Avatar
Dirt racer
I don't know if they are all the same but I took my C6 from my 75 4X4 that had a 360 I had changed to a 460 and swapped all the guts with a 77 car LTD C6 that had a 400, Same as a 460 bolt pattern and it worked great. All I knoticed was the center shafts were different length.
Old Apr 1, 2008 | 06:50 AM
whd507's Avatar
whd507
for that application, you should be fine. a $40 gasket set and a case of typeF and you are set.
Lincoln/T-bird/F-500 have differences, but useable, shouldnt be an issue for you.
the 78 may have a different shifter detent spring assy, you should be able to use your 74 valve body if you clean it out if that is the case.
Old Apr 1, 2008 | 09:25 AM
beartracks's Avatar
beartracks
There are variations in the number of clutches and the number of planetary gears at a minimum. The heavier the original application the heavier the tranny. Duh!
