Positive Crankcase ventilation
Old Sep 17, 2002 | 06:41 PM
Chevy_Monza's Avatar
Chevy_Monza
Good day,
I'm trying to figure out how my PCV system should be setup. The motor is not native to the truck. its an 85 351W with 2 barrel carb. As far as I can tell competely stock. Currently there is a PCV valve located on the rear of the passenger side. It connects to below the Carb. The PCV line on the front of the driver side, connects into the filter in the breather.
When the truck was purchased, it had a "standard" L shaped PCV Valve with only 1 place to hook up a line. The replacement part that was recommended for an 85 351W has a large connection, and a smaller one on top. It came with a plug to plug the top connection. Not seeing any lines to hook to, I plugged it. I'm constantly blowing oil up through the driver side valve cover and into my breather (and Carb).
Playing with the system, I find that should I remove the plug from the smaller connection on the PCV valve a) There is an annoying sucking sound as it sucks b) My other end stops smoking altogether. Should this smaller connection, also the size of a vacum line be connected anywhere ? There is a 3 tee connector just behind the engine on the firewall, where the valve for the breather plugs into...Perhaps there ?
My Haynes manual,which doesn't show HOW to connect the lines, does show a line running to a Evaporativ Valve. Don't ask me what that is. The motor currently does not have an EGR, and I don't think it ever has. I'm hoping somebody can explain where and if this line should be connected, if not maybe scan in a factory PCV setup for this motor ?
Chevy Monza
gm_monza(No Email Addresses In Posts!)
Old Sep 17, 2002 | 10:33 PM
airharley's Avatar
airharley
The way i set up my PVC system was to run the hose form one valve cover to the bottom of the carb base and the other has an aftermarket breather in it. The way you described yours is tock. The paper element is acting like a breather for the engine. It sucks clean air in and then routes it in one valve cover, through the engine, and then out the other valve cover into the intake system. Hope this helps.
Old Sep 17, 2002 | 10:58 PM
JTY's Avatar
JTY
1970XL351W
Mar 8, 2020 10:26 AM
nosehair
Nov 2, 2015 03:07 PM
kc10fo
1978 - 1996 Big Bronco
Jan 10, 2014 07:36 PM
taylorjgreen
Mar 20, 2011 11:09 AM
Ol' Blue
18
May 26, 2001 05:39 AM
